Hello. I write question first time in this page, so please let me know if I had some mistake. I use Autoware 1.13 in Ubuntu 18.04 and ROS Melodic, but it can't find some packages. I already use
source /install/setup.bash
This code is effective to find 'lidar_localizer' but not effective to find 'runtime_manager'. I should use
roslaunch runtime_manager runtime_manager
to start the autoware. Why the source command didn't applied in runtime_manager package? And, How can I use this package?
Originally posted by kasy on ROS Answers with karma: 1 on 2020-01-28
I assume you're using the release repo when you compiled it from the source. If that is the case, then there are two options,
  1. You could use Mate terminal
  2. Modify ~/autoware.ai/install/runtime_manager/share/runtime_manager/scripts/run script to accommodate your terminal. In my case, I was using Terminator terminal, hence I added the following lines,
elif [ $(which terminator) ]; then TERMINAL=terminator
Cheers.
Originally posted by Vicky with karma: 16 on 2020-01-31
