I am failing to integrate a ROS node with a Gazebo10 plugin. I am following this tutorial more or less but translating to the ROS2 API: http://gazebosim.org/tutorials?cat=guided_i&tut=guided_i6 . It seems that there is something wrong in my declaration of a subscription. I can't upload my file because I don't have 5 points, but I have copied the relevant code. I do not want to use gazebo_ros_pkgs.
    // Initialize ros, if it has not already been initialized
    if (!rclcpp::is_initialized())
      int argc = 0;
      char** argv = NULL;
      //rclcpp::init(argc, argv, rclcpp::init_options::NoSigintHandler);
      rclcpp::init(argc, argv);
    // Setup callback group
    this->rosCallbackGroup = this->rosNode->create_callback_group(
        rclcpp::callback_group::CallbackGroupType::MutuallyExclusive);
    // Setup subscriber options
    this->rosSubOptions = rclcpp::SubscriptionOptions();
    this->rosSubOptions.callback_group = this->rosCallbackGroup;
    // Setup subscriber
    this->rosSub = this->rosNode->create_subscription<std_msgs::msg::Float32>(
        "/" + this->model->GetName() + "/vel_cmd",
        rclcpp::QoS(1),
        boost::bind(&VelodynePlugin::OnRosMsg, this, _1),
        this->rosSubOptions);
Generating the following error:
In file included from /opt/ros/eloquent/include/rclcpp/client.hpp:31:0,
                 from /opt/ros/eloquent/include/rclcpp/callback_group.hpp:23,
                 from /opt/ros/eloquent/include/rclcpp/any_executable.hpp:20,
                 from /opt/ros/eloquent/include/rclcpp/memory_strategy.hpp:24,
                 from /opt/ros/eloquent/include/rclcpp/memory_strategies.hpp:18,
                 from /opt/ros/eloquent/include/rclcpp/executor.hpp:33,
                 from /opt/ros/eloquent/include/rclcpp/executors/multi_threaded_executor.hpp:25,
                 from /opt/ros/eloquent/include/rclcpp/executors.hpp:21,
                 from /opt/ros/eloquent/include/rclcpp/rclcpp.hpp:145,
                 from /ros2-dev/gazebo/.gazebo/plugins/velodyne/velodyne_plugin.cc:8: /opt/ros/eloquent/include/rclcpp/function_traits.hpp: In instantiation of ‘struct rclcpp::function_traits::function_traits<boost::_bi::bind_t<void, boost::_mfi::mf1<void, gazebo::VelodynePlugin, std::shared_ptr<std_msgs::msg::Float32_<std::allocator<void>
> > >, boost::_bi::list2<boost::_bi::value<gazebo::VelodynePlugin*>, boost::arg<1> > > >’: /opt/ros/eloquent/include/rclcpp/subscription_traits.hpp:90:8: required from ‘struct rclcpp::subscription_traits::has_message_type<boost::_bi::bind_t<void, boost::_mfi::mf1<void, gazebo::VelodynePlugin, std::shared_ptr<std_msgs::msg::Float32_<std::allocator<void>
> > >, boost::_bi::list2<boost::_bi::value<gazebo::VelodynePlugin*>, boost::arg<1> > >, void, void, void>’ /opt/ros/eloquent/include/rclcpp/node.hpp:199:5: required by substitution of ‘template<class MessageT, class CallbackT, class AllocatorT, class CallbackMessageT, class SubscriptionT, class MessageMemoryStrategyT> std::shared_ptr<SubscriptionT> rclcpp::Node::create_subscription(const string&, const rclcpp::QoS&, CallbackT&&, const rclcpp::SubscriptionOptionsWithAllocator<AllocatorT>&, typename MessageMemoryStrategyT::SharedPtr) [with MessageT = std_msgs::msg::Float32_<std::allocator<void>
>; CallbackT = boost::_bi::bind_t<void, boost::_mfi::mf1<void, gazebo::VelodynePlugin, std::shared_ptr<std_msgs::msg::Float32_<std::allocator<void>
> > >, boost::_bi::list2<boost::_bi::value<gazebo::VelodynePlugin*>, boost::arg<1> > >; AllocatorT = std::allocator<void>; CallbackMessageT
= <missing>; SubscriptionT = <missing>; MessageMemoryStrategyT = <missing>]’ /ros2-dev/gazebo/.gazebo/plugins/velodyne/velodyne_plugin.cc:128:32: required from here /opt/ros/eloquent/include/rclcpp/function_traits.hpp:52:82: error: decltype cannot resolve address of overloaded function
     typename function_traits<decltype( &FunctionT::operator())>::arguments>::type;
        ^ /opt/ros/eloquent/include/rclcpp/function_traits.hpp:57:72: error: decltype cannot resolve address of overloaded function    using argument_type = typename std::tuple_element<N, arguments>::type;
        ^ /opt/ros/eloquent/include/rclcpp/function_traits.hpp:59:95: error: decltype cannot resolve address of overloaded function    using return_type = typename function_traits<decltype( &FunctionT::operator())>::return_type;
        ^ /ros2-dev/gazebo/.gazebo/plugins/velodyne/velodyne_plugin.cc: In member function ‘void gazebo::VelodynePlugin::ExecutorThread()’: /ros2-dev/gazebo/.gazebo/plugins/velodyne/velodyne_plugin.cc:128:32: error: no matching function for call to ‘rclcpp::Node::create_subscription<std_msgs::msg::Float32>(std::__cxx11::basic_string<char>, rclcpp::QoS, boost::_bi::bind_t<void, boost::_mfi::mf1<void, gazebo::VelodynePlugin, std::shared_ptr<std_msgs::msg::Float32_<std::allocator<void>
> > >, boost::_bi::list2<boost::_bi::value<gazebo::VelodynePlugin*>, boost::arg<1> > >, rclcpp::SubscriptionOptions&)’
                                ^ In file included from /opt/ros/eloquent/include/rclcpp/executors/single_threaded_executor.hpp:28:0,
                 from /opt/ros/eloquent/include/rclcpp/executors.hpp:22,
                 from /ros2-dev/gazebo/.gazebo/plugins/velodyne/velodyne_plugin.cc:8: /opt/ros/eloquent/include/rclcpp/node.hpp:208:3: note: candidate: template<class MessageT, class CallbackT, class AllocatorT, class CallbackMessageT, class SubscriptionT, class MessageMemoryStrategyT> std::shared_ptr<SubscriptionT> rclcpp::Node::create_subscription(const string&, const rclcpp::QoS&, CallbackT&&, const rclcpp::SubscriptionOptionsWithAllocator<AllocatorT>&, typename MessageMemoryStrategyT::SharedPtr)    create_subscription(    ^~~~~~~~~~~~~~~~~~~ /opt/ros/eloquent/include/rclcpp/node.hpp:208:3: note:   substitution of deduced template arguments resulted in errors seen above make[2]: *** [CMakeFiles/velodyne_plugin.dir/velodyne_plugin.cc.o] Error 1 make[1]: *** [CMakeFiles/velodyne_plugin.dir/all] Error 2 make: *** [all] Error 2
Edit: Compilation solved. Switch boost::bind() to std::bind() (#include ) && switch _1 to std::placeholders::_1
Originally posted by errcsool on ROS Answers with karma: 26 on 2020-01-27
Comment by gvdhoorn on 2020-01-27:
I would recommend you edit your question and include a verbatim copy of the error message, then format it with the Preformatted Text button (the one with 101010 on it). As-is, the error message is almost unreadable.
Comment by errcsool on 2020-01-27:
Could you give me the points to upload a file? It would be much simpler
Edit: My function declaration OnRosMsg(const std_msgs::msg::Float32::SharedPtr) is correct. Switching from boost::bind to std::bind generates a different long error
Comment by gvdhoorn on 2020-01-27:\
there is no support to upload text files or source code. So giving you points would not seem to help.
If you intended to upload a screenshot then I would point you to the Support Guidelines which explicitly state you should not do that.
I intend to use the attachment (paperclip) function on the edit bar
That only allows image type attachments. Not sure whether that is because of configuration or just how Askbot works.
Please post your last edit as an answer and accept your own answer.
I can't accept my own answer, as I need >10 points.
Comment by gvdhoorn on 2020-01-28:
I've accepted it for you.
Thanks for reporting your solution and for posting it as an answer.
Originally posted by errcsool with karma: 26 on 2020-01-27
It would be even nicer if you could include a short code-snippet that shows the exact syntax. Future readers may not be able to translate your answer into code themselves.
