Hello,
I installed the latest version of raspbian on both RPI 3 and 4 and it just does not compile
/home/pi/ros_catkin_ws/src/rospack/include/rospack/rospack.h:108:10: fatal error: boost/tr1/unordered_set.hpp: No such file or directory
I first read it was becos RPI4 was too new, but apparently something is broken
I followed this tutorial : http://wiki.ros.org/ROSberryPi/Installing%20ROS%20Kinetic%20on%20the%20Raspberry%20Pi
I use : 2019-09-26-raspbian-buster.img
how can I fix this ?
thanks
Originally posted by phil123456 on ROS Answers with karma: 51 on 2020-01-25
There is currently no version of ROS targeting Debian Buster. It looks like you're trying to install a version of ROS targeting an older version of boost (<1.63) than the one available on your system (Buster 1.67). In your version these headers don't exist anymore.
The header names have been updated in later versions of ROS https://github.com/ros/rospack/pull/80.
You could to try to compile ROS Melodic rather than ROS Kinetic that targets more recent OSes. You should be able to follow the same instructions and just replace kinetic with melodic in the commands.
Originally posted by marguedas with karma: 3606 on 2020-01-25
Comment by phil123456 on 2020-01-25:
jolly good, I'll give it a try, I am a complete noob, so... thanks
Comment by phil123456 on 2020-01-26:
ok so it works, it crashed on compilation but I just reran it with the -j2 option
Comment by marguedas on 2020-01-26:
Glad it worked for you,
You can mark the answer as accepted by clicking the checkmark, this will let the community know that this has been solved and doesn't need additional invstigation
