Hello, I'm working with ROS kinect on Ubuntu 16.04.
I'm trying to make my own navigation file based on turtlebot.
As far as I know, it is essential to make the robot be in the same place and pose with these of when it started to make its map.
But what I can do now is just,
roslaunch turtlebot_gazebo turtlebot_world.launch
Of course I can insert garage willow in gazebo after I launch the above,
but, I can't load the file I saved which has turtlebot and garage willow.
What I want to do is,
to make the turtlebot is in the garage willow filed with the same place and pose with those of when I made the map of garage
Anyone who can give me help?
Thanks in advance.
Originally posted by kane_choigo on ROS Answers with karma: 195 on 2020-01-22
When saving a world in Gazebo you don't save it with the robot in it, you have to create your world with only your obstacles and then save the world. To add your robot in a world you use a service : /gazebo/spawn_urdf_model that is called when you use the node spawn_model(you can find it here in the kobuki.launch that is included from turtlebot_world.launch).
To tell which world you want to use there is the argument world_file in the turtlebot_world.launch so you just have to specify it when using roslaunch :
roslaunch turtlebot_gazebo turtlebot_world.launch world_file:=/PATH/TO/YOUR/WORLD
You can also modify the launch file to change the default value, or in that case the launch file use the environment variable TURTLEBOT_GAZEBO_WORLD_FILE so you can set it in your terminal to the path of your world file using :
export TURTLEBOT_GAZEBO_WORLD_FILE = /PATH/TO/YOUR/WORLD
Now when you call the service to spawn the model you can specify the position you want for the robot:
 <node name="spawn_turtlebot_model" pkg="gazebo_ros" type="spawn_model"
        args="-x 0 -y 0 -Y -unpause -urdf -param robot_description -model mobile_base"/>
You have to use the arguments -x, -y, -z, -R, -P, -Y to set x, y, z and the roll, pitch and yaw of our robot.
Originally posted by Delb with karma: 3907 on 2020-01-24
