I'm trying to create a catkin wrapper to build a library from external files. I'm usually using catkin_simple. However, the header files here are not contained in the include directory. I'm trying to figure out where to install them so that I can use #include <AdsLib/AdsLib.h> in other catkin packages to use this library.
Looking at catkin_simple's cs_install macro, I tried to add my header files. However, other packages can still not find the includes.
Edit: The files exist in install/include. But it seems like the build system is looking for them in the devel or source space. Since catkin_simple is only including from the include folder, I tried to add catkin_package(INCLUDE_DIRS ${SOURCE_DIR}/AdsLib). But the command is executed before the external project folder is cloned, which leads to an error.
What am I missing?
CMakeLists.txt:
project(ads_catkin)
find_package(catkin_simple REQUIRED)
catkin_simple()
include(ExternalProject)
ExternalProject_Add(ads
    PREFIX ${CATKIN_DEVEL_PREFIX}/ads
    GIT_REPOSITORY https://github.com/Beckhoff/ADS.git
    GIT_TAG 6b3a03009a757cf651fe44d8be7b6df698028f0e
    #GIT_TAG master
    CONFIGURE_COMMAND ""
    UPDATE_COMMAND ""
    BUILD_COMMAND ""
    INSTALL_COMMAND ""
    BUILD_BYPRODUCTS
        <SOURCE_DIR>/AdsLib/AdsDef.cpp
        <SOURCE_DIR>/AdsLib/AdsLib.cpp
        <SOURCE_DIR>/AdsLib/AmsConnection.cpp
        <SOURCE_DIR>/AdsLib/AmsPort.cpp
        <SOURCE_DIR>/AdsLib/AmsRouter.cpp
        <SOURCE_DIR>/AdsLib/Frame.cpp
        <SOURCE_DIR>/AdsLib/Log.cpp
        <SOURCE_DIR>/AdsLib/NotificationDispatcher.cpp
        <SOURCE_DIR>/AdsLib/Sockets.cpp
        <SOURCE_DIR>/AdsLib/AdsDef.h
        <SOURCE_DIR>/AdsLib/AdsLib.h
        <SOURCE_DIR>/AdsLib/AdsNotification.h
        <SOURCE_DIR>/AdsLib/AmsConnection.h
        <SOURCE_DIR>/AdsLib/AmsHeader.h
        <SOURCE_DIR>/AdsLib/AmsPort.h
        <SOURCE_DIR>/AdsLib/AmsRouter.h
        <SOURCE_DIR>/AdsLib/Frame.h
        <SOURCE_DIR>/AdsLib/Log.h
        <SOURCE_DIR>/AdsLib/NotificationDispatcher.h
        <SOURCE_DIR>/AdsLib/RingBuffer.h
        <SOURCE_DIR>/AdsLib/Router.h
        <SOURCE_DIR>/AdsLib/Semaphore.h
        <SOURCE_DIR>/AdsLib/Sockets.h
        <SOURCE_DIR>/AdsLib/wrap_endian.h
        <SOURCE_DIR>/AdsLib/wrap_socket.h
ExternalProject_Get_Property(ads SOURCE_DIR)
include_directories(
    ${SOURCE_DIR}
cs_add_library(AdsLib
    ${SOURCE_DIR}/AdsLib/AdsDef.cpp
    ${SOURCE_DIR}/AdsLib/AdsLib.cpp
    ${SOURCE_DIR}/AdsLib/AmsConnection.cpp
    ${SOURCE_DIR}/AdsLib/AmsPort.cpp
    ${SOURCE_DIR}/AdsLib/AmsRouter.cpp
    ${SOURCE_DIR}/AdsLib/Frame.cpp
    ${SOURCE_DIR}/AdsLib/Log.cpp
    ${SOURCE_DIR}/AdsLib/NotificationDispatcher.cpp
    ${SOURCE_DIR}/AdsLib/Sockets.cpp
add_dependencies(AdsLib ads)
cs_install()
install(DIRECTORY ${SOURCE_DIR}/
        DESTINATION ${CATKIN_GLOBAL_INCLUDE_DESTINATION}
        FILES_MATCHING PATTERN "*.h" PATTERN "*.hpp"
cs_export(
And the error:
In file included from /home/xxx/xxx/src/xxx/nav_controller/src/controller.cpp:19:0:
/home/xxx/xxx/src/Navion/nav_controller/include/nav_controller/controller.h:27:10: fatal error: AdsLib/AdsLib.h: No such file or directory
Originally posted by prex on ROS Answers with karma: 151 on 2020-01-18
I switched to the DownloadProject Cmake module, which works perfectly fine now: https://github.com/Crascit/DownloadProject
The problem was that the steps from cs_export were executed before the source code was downloaded.
Originally posted by prex with karma: 151 on 2020-01-22
