Hi,
With the
ros2 bag record
command I can easily start recording data to a bag file. Is it possible the start recording in with a launch file? I would like to start some nodes from this launch file and start recording, as well.
Thanks for your help.
Originally posted by tlaci on ROS Answers with karma: 48 on 2020-01-14
You should be able to launch the ros2 bag record command as an executable. For example, recording all topics:
import launch
    return launch.LaunchDescription([
        launch.actions.ExecuteProcess(
            cmd=['ros2', 'bag', 'record', '-a'],
            output='screen'
and the XML equivalent if you are using ROS Eloquent or newer:
<launch>
  <executable cmd="ros2 bag record -a" output="screen" />
</launch>
Originally posted by jacobperron with karma: 1870 on 2020-01-17
Comment by justinberi on 2021-05-25:
Is anyone else experiencing an issue with this? When I ctrl-c the launch bag always dies.
The launch file:
    return LaunchDescription([
    ExecuteProcess(cmd=['ros2', 'bag', 'record', '-a'], output='screen', log_cmd=True),
On ctrl-c:
[ERROR] [ros2-2]: process has died [pid 40507, exit code 2, cmd 'ros2 bag record -a'].
And the tables in the sqlite database seem corrupt.
Comment by ljaniec on 2022-03-25:
@justinberi I think that better place to ask for it would be a GitHub issue there: https://github.com/ros2/rosbag2 You can prepare your MWE and error description etc. and maybe get answers directly from maintainers
