Dear all,
I am trying to use Robot Navigation DWBLocalPlanner in Move_Base_Flex, but I am having troubles in configuring local_costmap.yaml. In order to use the costmap layers it is need to load the CostmapAdapter interface so the costmap layers are loaded in DWB namespace. Is this loaded as a layer-like plugin under local_costmap which will automatically point to DWB or shall it be configured a new namespace? Shall it be enhanced with costmap_queue?
Running under Ubuntu 18.04 ROS melodic.
Here is the configuration that I am following:
local_costmap:
  width: 9.0
  height: 9.0
  resolution: 0.05
  static_map: false
  rolling_window: true
  global_frame: map
  robot_base_frame: base_link
  update_frequency: 25.0
  publish_frequency: 5.0
  map_type: costmap
  obstacle_range: 4.5
  raytrace_range: 4.5
  publish_voxel_map: false
  transform_tolerance: 0.5
  meter_scoring: true
  footprint: [[-0.51, -0.52], [-0.51, 0.52], [0.79, 0.42], [0.79, -0.42]]
  footprint_padding: 0.15
  plugins:
    # - {name: static_layer, type: "costmap_2d::StaticLayer"}
    - {name: costmap_ros , type: "nav_core_adapter::CostmapAdapter"}
    - {name: laser_horizontal_layer, type: "costmap_2d::ObstacleLayer"}
    # - {name: rgbd_layer, type: "costmap_2d::ObstacleLayer"}
    - {name: laser_cliff_layer, type: "costmap_2d::VoxelLayer"}
    - {name: inflation_layer, type: "costmap_2d::InflationLayer"}
Thanks in advance.
Originally posted by Sgm on ROS Answers with karma: 11 on 2020-01-11
Comment by David Lu on 2020-01-24:
What's not working at the moment?
Comment by Sgm on 2020-01-25:
DWB planner is working fine. But is not able to load the local costmap, so dynamic obstacles in the path are not avoided. I am wondering how I am supposed to load the plugin. I think that for having that behavior I need to load the CostmapAdapter plugin, to have the local_costmap loaded in nav_core2 so it can be considered in the planner. Right? Whenever I try it I get the following error:
what():  According to the loaded plugin descriptions the class nav_core_adapter::CostmapAdapter with base class type costmap_2d::Layer does not exist. Declared types are  costmap_2d::InflationLayer costmap_2d::ObstacleLayer costmap_2d::StaticLayer costmap_2d::VoxelLayer range_sensor_layer::RangeSensorLayer social_navigation_layers::PassingLayer social_navigation_layers::ProxemicLayer
Since I am using the LocalPlannerAdapter I thought I did not need to use the CostmapAdapter, because everything was running on nav_core and the local_costmap would be loaded in DWB.
Hope this clarifies.
Comment by David Lu on 2020-01-27:
How are you loading the planner itself?
Comment by Sgm on 2020-01-27:
I have a configuration file for the local planners.Where I set the 'name' and 'type' of BaseLocalPlanner and using the nav_core_adapter::LocalPlannerAdapter. As it follows:
controllers:
  - name: 'BaseLocalPlanner'
    type: 'nav_core_adapter::LocalPlannerAdapter'
LocalPlannerAdapter:
  planner_name: dwb_local_planner::DWBLocalPlanner
DWBLocalPlanner:
  ###### DWB Configuration Parameters ######
  # The minimum x velocity for the robot in m/s
  min_vel_x: 0.0
I am able to avoid obstacles with other planners such as previous dwa versions or teb.
I see that the planner can work in two different ways:
1- Running on old nav_core : For that it is needed to use LocalPlannerAdapter interface to have DWB loaded in the old nav_stack. For this way the planner should use the local_costmap as it is in the old nav stack.
2- Running on nav_core2. Use directly the BasicCostmap or use CostmapAdapter interface to load Costmap2D
Comment by artemiialessandrini on 2020-05-19:
Hi, @Sgm, could you please explain how you got mbf and DWB_local_planner working together? I set my local planner the same way using Adapter, but still facing errors, while planning /move_base_simple/goal
Because you are already using the LocalPlannerAdapter, you do not need to manually use the CostmapAdapter. It does it automatically.
Originally posted by David Lu with karma: 10932 on 2020-01-28
