Steps taken so far:
I have downloaded the raspberry pi image and VM image as per: http://wiki.ros.org/ROSberryPi/Installing%20ROS%20Kinetic%20on%20the%20Raspberry%20Pi
https://downloads.ubiquityrobotics.com/
pi image extracted to raspberry pi 3 B+.
VM image extracted to Oracle VM VirtualBox
I installed the create_autonomy package: http://wiki.ros.org/create_autonomy
I created a cable from Create 2 DIN plug to the pi USB using FTDI level shifter from 5V (create 2) to 3.3V (raspberry pi).
I turn on the create 2 and plug in the serial/USB cable from the create 2 and the pi, and type:
ls /dev
it returns ttyUSB0
typing:
lsusb
returns the FTDI controller info
I run the roslaunch ca_driver create_2.launch from the VM (ssh'd to the raspberry pi), but it does not connect to the Create 2.
getting this error:
[create::Serial] failed to receive data from Create. Check if robot is powered!
On the FTDI controller, I can see the send and receive LED lights light up when the program is sending data to the create 2.
I have checked the cable pinout and verified TX and RX are correct. Also checked for continuity of the TX and RX wires with a ohm meter.
I download, extracted and ran the Create2CSharp_DrivingProgram.exe as per the pdf and it works fine. https://docs.google.com/viewer?url=https%3A%2F%2Fwww.irobotweb.com%2F-%2Fmedia%2FMainSite%2FPDFs%2FAbout%2FSTEM%2FCreate%2FCreate_2_Tethered_Driving_2.pdf
running roslaunch ca_driver create_2.launch from terminal...
ubuntu@buddybot:~/create_ws/src/create_autonomy/ca_driver/config$ roslaunch ca_driver create_2.launch
... logging to /home/ubuntu/.ros/log/6fb2a544-d0dc-11e5-a2fa-c9da98e38caa/roslaunch-buddybot-2311.log
Press Ctrl-C to interrupt
xacro: Traditional processing is deprecated. Switch to --inorder processing!
To check for compatibility of your document, use option --check-order.
For more infos, see http://wiki.ros.org/xacro#Processing_Order
xacro.py is deprecated; please use xacro instead
started roslaunch server http://buddybot.local:44067/
SUMMARY
PARAMETERS
 * /ca_driver/base_frame: base_footprint
 * /ca_driver/dev: /dev/ttyUSB0
 * /ca_driver/latch_cmd_duration: 0.2
 * /ca_driver/loop_hz: 10.0
 * /ca_driver/odom_frame: odom
 * /ca_driver/publish_tf: True
 * /ca_driver/robot_model: CREATE_2
 * /robot_description: <?xml version="1....
 * /rosdistro: kinetic
 * /rosversion: 1.12.14
NODES
    ca_driver (ca_driver/ca_driver)
    robot_state_publisher (robot_state_publisher/robot_state_publisher)
ROS_MASTER_URI=http://buddybot.local:11311
process[ca_driver-1]: started with pid [2331]
process[robot_state_publisher-2]: started with pid [2333]
[ INFO] [1577558516.039614572]: [CREATE] "CREATE_2" selected
[create::Create] retrying to establish serial connection...
[create::Serial] serial error - Operation canceled
[create::Create] failed to connect over serial: timeout
[FATAL] [1577558561.081052080]: [CREATE] Failed to establish serial connection with Create.
[create::Serial] send failed, not connected.
[ca_driver-1] process has finished cleanly
Found the log: /home/ubuntu/.ros/log/6fb2a544-d0dc-11e5-a2fa-c9da98e38caa/roslaunch-buddybot-2311.log
I reviewed the log, and only one ERROR is generated:
[roslaunch][ERROR] 2019-12-28 13:33:03,228: [ca_driver-1] escalating to SIGTERM
Reading some other questions related to pi ttyUSB0, I ran this:
/dev/ttyUSB0
and it returned this:
-bash: /dev/ttyUSB0: Permission denied
Ran this:
groups ubuntu
Returned this:
ubuntu : ubuntu adm tty dialout cdrom floppy sudo audio video plugdev users input ssl-cert bluetooth gpio i2c spi
I verified the dialout group exists:
Ran:
groups
Returned this:
ubuntu adm tty dialout cdrom floppy sudo audio video plugdev users input ssl-cert bluetooth spi i2c gpio
Ran this:
sudo chmod 666 /dev/ttyUSB0
logged out, logged in, but still get the permission denied.
Ran this:
sudo chmod 777 /dev/ttyUSB0
Logged out, logged in, can run /dev/ttyUSB0 now, and run "roslaunch ca_driver create_2.launch" in another terminal.
When "roslaunch ca_driver create_2.launch" is run, the other terminal running /dev/ttyUSB0 displays:
-bash: /dev/ttyUSB0: **Permission denied**
Ran:
sudo usermod -a -G tty ubuntu
sudo usermod -a -G dialout ubuntu
but no help, "roslaunch ca_driver create_2.launch" still fails to connect.
Ran this again:
/dev/ttyUSB0
returns
So, I think it is something with permissions on ttyUSB0
I found this for same/similar issue with turtlebot: https://answers.ros.org/question/11185/cant-access-turtlebot-through-ttyusb0/?answer=3582%3Fanswer%3D3582#3582
Instructing to add this:
#serial usb
SUBSYSTEM=="usb", ATTRS{idProduct}=="6001", ATTRS{idVendor}=="0403", MODE="0666", GROUP="turtlebot"
Following the answer, I found /etc/udev/rules.d/99-com.rule.
I verified the product and vendor with lsusb
Bus 001 Device 004: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Contents of 99-com.rule after adding the line:
SUBSYSTEM=="input", GROUP="input", MODE="0660"
SUBSYSTEM=="i2c-dev", GROUP="i2c", MODE="0660"
SUBSYSTEM=="spidev", GROUP="spi", MODE="0660"
SUBSYSTEM=="bcm2835-gpiomem", GROUP="gpio", MODE="0660"
SUBSYSTEM=="gpio*", PROGRAM="/bin/sh -c '\
        chown -R root:gpio /sys/class/gpio && chmod -R 770 /sys/class/gpio;\
        chown -R root:gpio /sys/devices/virtual/gpio && chmod -R 770 /sys/devices/virtual/gpio;\
        chown -R root:gpio /sys$devpath && chmod -R 770 /sys$devpath\
KERNEL=="ttyAMA[01]", PROGRAM="/bin/sh -c '\
        ALIASES=/proc/device-tree/aliases; \
        if cmp -s $ALIASES/uart0 $ALIASES/serial0; then \
                echo 0;\
        elif cmp -s $ALIASES/uart0 $ALIASES/serial1; then \
                echo 1; \
        else \
                exit 1; \
        fi\
'", SYMLINK+="serial%c"
KERNEL=="ttyS0", PROGRAM="/bin/sh -c '\
        if cmp -s $ALIASES/uart1 $ALIASES/serial0; then \
                echo 0; \
        elif cmp -s $ALIASES/uart1 $ALIASES/serial1; then \
                echo 1; \
        else \
                exit 1; \
        fi \
#serial usb
SUBSYSTEM=="usb", ATTRS{idProduct}=="6001", ATTRS{idVendor}=="0403", MODE="0666", GROUP="ubuntu"
Question: What GROUP should be added to #serial usb line?
the user?
ttyUSB0?
tty?
Originally posted by lotharchris on ROS Answers with karma: 16 on 2019-12-28
After troubleshooting with realterm, I determined the create 2 cable that came with my create 2 was bad. The receive channel/wire had intermittent connection. I contacted irobot support, they sent me a new cable, and the create 2 connects now and shows the battery level.
Originally posted by lotharchris with karma: 16 on 2020-01-06
