I want to implement RRT for motion planning of a robotic arm. I searched a lot on the internet to get some sample code of RRT for motion planning, but I didn't get any. Can someone please suggest a good source where I can find RRT implemented in C++ for any type of motion planning.
The OMPL library has some good quality implementations of several sampling-based motion planners, as listed here : http://ompl.kavrakilab.org/planners.html
In particular, you can find several variants of RRT under the BSD license.
The first hit on GitHub gives me the following implementation, which is what you seem to be looking for.
https://github.com/RoboJackets/rrt
You can follow this GitHub repository to find RRT, RRT* and RRT with dynamic vehicle constraints (Dubin's dynamics).
https://github.com/ManashRaja/rrt-star-dubins-sim
It has a simple codebase to learn the implementation in C++ and modify as per your requirement.
Here is the minimalistic implementation of RRT for ROS in C++.
Requirements
  1. You should have ROS (latest version) installed on your system
  2. Use Linux OS to install ROS
Link to the repo:- https://github.com/Safire-AI/RRT
