I plan to build a mechanism with multiple axis, which is similar to a robot. To start, I need to define some specifications such as repeatable precision, speed, acceleration, and payload. Then the motor and structure is selected and designed based on these parameters. After that, I need to choose methods to manufacture these components. I would like to consult experienced experts in this forum that is there any suggested books, textbooks, or website resources I can learn these knowledge?
$\begingroup$ Have you considered standards also? $\endgroup$ – 50k4 Mar 12 '16 at 8:32
$\begingroup$ Welcome to Robotics, Superuser. As it stands, I think your question is too broad. You ask for references on setting specifications and manufacture. Determining aspects of mechanisms such as limiting speeds, accelerations, weights, etc. is typically the subject of quite a few collegiate courses - physics, statics, dynamics, mechanical system dynamics, and, debatably, kinematics and structural analysis. If you could provide one aspect of a specific scenario then maybe someone here could help, but with the scope you seek, your best resource would be your local university. $\endgroup$ – Chuck Mar 18 '16 at 13:15
$\begingroup$ Stack exchange is not a discussion forum, it is a place to ask practical, answerable questions based on actual problems that you face. If you wish to discuss robotics you can use Robotics Chat. Please take a look at How to Ask and tour for more information on how stack exchange works. $\endgroup$ – Mark Booth♦ Mar 18 '16 at 17:24
You could look at three books.
- A Mathematical Introduction to Robotic Manipulation - S.Sastry, X.Li and R.Murray provides a theoretical foundation to the kinematics, dynamics and control aspects of robotic manipulators. The only downside to this book is that it lacks in algorithmic content like that available in Probabilistic Robotics - Sebastian Thrun
- Robotic Engineering An Integrated Approach deals with the A to Z of designing a robotic manipulator. It gives you a theoretical overview of the fundamental concepts. In terms of design it takes you from requirements through implementation and practical considerations while choosing actuators, computing systems etc. The downside for this book is the same as the previous book.
- Mechanical Design of Robots covers mechanical engineering topics such as stresses, strains, structures, linkages etc. It is a book to help you design a robotic system from a functionality standpoint. The author maintains that design of robots should not necessarily compromise on aesthetic values by always going by the worst case scenario.
$\begingroup$ Thank you very much for your sharing. It is helpful. I will start to study them. $\endgroup$ – Superuser Mar 24 '16 at 9:22
