Hi All,
I am trying to install rosserial library on ros kinetic and ros_lib for Arduino IDE.
I followed link#0 instruction for rosserial manual installation.
All steps finished successfully (rosserial_windows required partial installation of common_msgs library).
After I continued to "2.2 Install ros_lib into the Arduino Environment" link#1, I got ImportError: No module named rosserial_client.
I performed again w/ no success:
catkin_make -DCATKIN_WHITELIST_PACKAGES=rosserial_client
catkin_make install-DCATKIN_WHITELIST_PACKAGES=rosserial_client
Please give me some hint.
Thanks
Originally posted by roDiBgu on ROS Answers with karma: 26 on 2019-11-11
Comment by gvdhoorn on 2019-11-12:
There is no need to install rosserial from source (ie: build in your workspace), provided you are running a supported OS on a supported platform. It has been released into Kinetic quite some time ago already for amd64, arm64 and armhf on Debian and Ubuntu. Just run sudo apt install ros-kinetic-rosserial.
See also #q320046 for some info on how to determine whether you can install something using apt.
Comment by roDiBgu on 2019-11-12:
@gvbhoorn, thanks for your reply
I tried using sudo apt-get install-kinetic-rosserial I got: E: Unable to locate package ros-kinetic-rosserial
Also: sudo apt install-kinetic-rosserial I getting: E: Unable to locate package ros-kinetic-rosserial
Have I missed something? Should I run this commands from some specific folder?
According to the status pages (see #q320046 again for an explanation), rosserial has been released for Kinetic on amd64, arm64 and armhf, but perhaps not for your OS.
Are you running something other than Debian or Ubuntu? Or using an unsupported platform? How did you install ROS?
What is the output of lsb_release -a and uname -rvmp?
@gvdhoorn
I am using Raspbian Stretch OS, ROS has some compilation issue w/ Buster and I am not skilled enough for t/s
ROS installed according to Link#2
lsb_release -a --> Description: Raspbian GNU/Linux 9.11 (stretch) uname -rvmp --> 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l unknown
Comment by gvdhoorn on 2019-11-12:\
that would indeed be one of the cases where apt wouldn't work, as you've compiled ROS from sources.
So in your case installing rosserial from sources makes sense -- and this is also one of the cases discussed in #q320046).
@gvdhoorn Thanks for your support, I will go over #q320046 for better understanding of this issue
I assume the issue was solved by
$ source devel/setup.bash (was executed again after rosserial library installation link#0)
After, executed command rosrun rosserial_arduino make_libraries.py
ros_lib was successfully created in Arduino sketchbook/libraries/ folder
I think the question can be closed.
Originally posted by roDiBgu with karma: 26 on 2019-11-12
