Hello! I'm using ROS kinetic on ubuntu 16.04.
And I'm going to make my own message consisting of many sub-custom messages.
The sub-messages are in the right directory where any other messages are defined.
Below is a sample of the messages.
my_msgs/StateError          stateError              # error for state
my_msgs/EvalCovariance      evalCovariance          # validate covariance
and my_msgs is the name of the directory. (In other words, StateError messages and EvalCovariance messages are all in the my_msgs directory.)
In this case, is it mandatory to drop my_msgstags because they're all in the same directory?? (like this)
Thanks in advance :)
Originally posted by kane_choigo on ROS Answers with karma: 195 on 2019-11-11
to define a message based on different messages (sub-messages) that are defined in same package you have two options:
  1. you drop the package name before these messages because the sub-messages are defined in same package
  1. you indicate the package_name before these sub-messages (not the directory_name) :
package_name/StateError         stateError
package_name/EvalCovariance     evalCovariance
so, if my_msgs is your package_name, both samples you wrote in the question are valid. But, if my_msgs is just a directory_name then you need to use the second sample without attaching my_msgs/
Originally posted by mali with karma: 146 on 2019-11-12
Comment by kane_choigo on 2019-11-12:
Thank you so much for your short and clear advice. I really appreciate it.
