Hello everyone,
I would like to create simple octomap with use of both RealSense D435 and T265 cameras. I am using my own RealSense wrapper (do not ask why please, it is needed in this case). I can publish PointCloud from D435 camera (depth stream) and pose (odometry) from T265 as a topic.
What I am currently struggling with is publishing tf. I know, that octomap_server can incrementally build occupancy grid based on odometry received from tf. I just cannot figure out, how to setup frame_id's and so.
This is how I broadcast transform:
tf_br.sendTransform(tf::StampedTransform(transform, ros::Time::now(), "tf_t265", "map"));
The transform object is filled with the exact same data as I am using in the topic for publishing T265 pose (which is being used and it works).
This is what the part of my launchfile for octomap_server looks like:
<node pkg="octomap_server" type="octomap_server_node" name="octomap_server">
        <param name="resolution" value="0.05" />
        <!-- fixed map frame (set to 'map' if SLAM or localization running!) -->
        <param name="frame_id" type="string" value="tf_t265" />
        <!-- maximum range to integrate (speedup!) -->
        <param name="sensor_model/max_range" value="5.0" />
        <!-- data source to integrate (PointCloud2) -->
        <remap from="cloud_in" to="/d435/depth" />
</node>
I suspect, that frame_id param is the key here, but I tried to set it to map and it does not work too. I know, that maybe I am publishing the transform incorrectly, but this is why I am asking for help. There is nothing else in my code related with tf broadcasting.
If any additional info is needed, please let me know. Thank you for any help!
Have a nice day.
Originally posted by eMrazSVK on ROS Answers with karma: 41 on 2019-10-21
Comment by Jari on 2019-10-21:
I know you said don't ask but I'm genuinely curious ... (and I assume it has more to do with the t265 than the d435) ... why did you write your own RealSense wrapper :D ?
Comment by eMrazSVK on 2019-10-22:
Because I need only basic functionality from librealsense inside ROS. Furthermore I am developing application on Nvidia Jetson and D435+T265 simultaneously don't even work with RealSense wrapper. I am also maintaining a big ros package, where I have my own realsense node. If I was using realsense-ros as a module it would be difficult to maintain, because it is under heavy development and so it is updated too often. When I update core librealsense, my ROS wrapper still works. The realsense ROS wrapper is not hard to write though. + I needed to implement some features which weren't implemented (I dont know if it's still the case) in original RealSense ROS wrapper such as T265 complete camera reset (start/stop pipeline) or odometry Set (setting odometry to specific pose with service using transformation). It is much more flexible now for me as I have stable setup consisting of D435+T265. Hope I made it clear enough ;)
Comment by Jari on 2019-10-22:
That makes a lot of sense. Is any is this open source perchance? I'd like to look through it if that's the case.
No, it's not available anywhere for now.
Comment by Dookei on 2020-04-08:
Hi @eMrazSVK I am trying to perform the same as you in octomap with T265 and D435i. Currently(contrary to you I am using the realsenselib) The pose and depth point cloud are working as expected( light modifications to the rs_d400_and_t265.launch). When I run the octomap-server, after a few secs, I get MessageFilter [target=/t265/odom/sample ]: Dropped 100.00% of messages so far. Any idea what that might be? Any help would be much appreciated.
I'm answering my own question. The solution was to add transform between pointcloud_frame_id and map frame (this fact is clearly stated in the octomap_server docs so it seems I cannot read). It is still strangely rotated, but that would be again some wrong transform.
Originally posted by eMrazSVK with karma: 41 on 2019-10-22
