Hello.
- Autoware version : 1.12.0
- ROS Version : Melodic
- Autoware installed from Docker
- Docker version 19.03.2, build 6a30dfc
I am trying to run the demo of autoware here : https://gitlab.com/autowarefoundation/autoware.ai/autoware/wikis/ROSBAG-Demo
But I am experiencing a lot of problems.
First of all, I download the files, create a .autoware
in my personal home and extract the files there.
I start autoware by running the run.sh
file, I am now connected with the autoware
user 'in' the docker container.
But then the first instruction is to move to the directory autoware.ai
which doesn't exist !
The right folder seems to be
/home/autoware/Autoware
Then I source the setup.bash file.
I start the runtime manager with
roslaunch runtime_manager runtime_manager.launch
Then I move to the simulation
tab and try to load the bag file from ~/.autoware
but the folder doesn't contain my files...
I am truly lost, and I can't see what I did wrong. Thanks for the help !
[Edit] I made it working by using ~/Autoware
instead of ~/autoware.ai
(In the docker machine)
Then I copied the ~/.autoware
from the host to the docker machine and It's fine.
Do you think I did something wrong or the documentation maybe deserves a pull request ?
Originally posted by Mackou on ROS Answers with karma: 196 on 2019-10-03
