tldr - Here are my answers to your questions, I'll go in a bit more details after
Does this mean that ROS2 is using
non-standard serialisation? Looking at
the code it seems that serialisation
happens independently in the ROS2 RMW
layer and is then submitted as a
serialized packet to a topic typed by
ConnextStaticSerializedData, whatever
the original type. This happens for
custom types, but e.g. not for the
rq/…/list_parametersRequest and other
built-in types.
We are using a workaround to access the serialized code directly without deserializing to write it e.g. in rosbags. RTI Connext doesn't provide this functionality out of the box. That's why we implemented a way of type masquerading to do so - it's not really that, but it's somewhat similar.
It was only implemented for topics to make pub/sub work. Therefore, you don't see that on services.
Any way to avoid this behavior? It is
quite annoying from an
interoperability point of view (Admin
console, but also other non ROS2
DDS-based applications).
We are aware of the mismatch with RTI's Admin Console, but AFAICT there is no workaround. I am not quite sure if I understand your point on non ROS2 DDS-based applications. Our workaround is safe to use between multiple DDS vendors and is wire compatible (we run quite a few cross talking tests on the ROS2 buildfarm, e.g. Connext and FastRTPS).
Does the behavior change when I would
use IDL instead of msg files? I didn't
find a way to get that working
although it should work on Dashing.
No. The message generation step is independent from the way we send it over the wire.
The change got introduced as a prerequisite for having Connext support rosbags. In order to speed up the write process, it's kind of necessary to obtain an incoming message without deserializing it first, then re-serialize it and write it to disk. Whereas FastRTPS made it quite easy to get access to the buffer with the serialized (CDR) data, there was no straight forward way to do so in Connext.
After discussing with RTI, we've developed that workaround together which essentially publishes a sequence of octets (shown as ConnextStaticSerializedData
) which holds the CDR data. We had to patch the API of Connext in order to support that. The changes and more patch files can be found here: https://github.com/ros2/rmw_connext/blob/master/rmw_connext_cpp/resources/patch_files/connext_static_serialized_dataPlugin.cxx.patch#L42-L51
We declare the type of this message however as the actual data type of the message, e.g. std_msgs::msg::String
to be wire compatible. https://github.com/ros2/rmw_connext/blob/master/rmw_connext_cpp/src/rmw_publisher.cpp#L141-L152
Needless to say, we did the same workaround for subscribers.
The patch files applied are only compatible for Connext 5.3.1. These patch files have to be modified to match Connext 6.0.0, which we haven't done yet. The patched code is used for publishing in any case, whether you publish serialized code or ROS2 message instances. We could technically refactor the code to only apply the ConnextStaticSerializedData
workaround when publishing serialized code. That would however introduce another level of inconsistency.
Originally posted by Karsten with karma: 643 on 2019-09-09
Comment by qootec on 2019-09-10:
Hi Karsten, thanks for your extensive answer.
(from my question) It is quite annoying from an interoperability point of view (Admin console, but also other non ROS2 DDS-based applications).
This was based on an assumption of mine, but I guess I assumed wrongly… I thought that if Admin Console has a problem, other pure DDS applications would also run into the same issue, certainly in case they would be based on DDS Dynamic Data.
(from your reply) We declare the type of this message however as the actual data type of the message, e.g. std_msgs::msg::Stringto be wire compatible.
It seems that my DDS knowledge is insufficient to understand that you can send the correct metadata through the (patched) RTI API, but that the receiving application can still get confused about the topic's type. I would expect that the metadata is the only truth about a topic's content. This shows a lack in my RTPS/CDR knowledge, but that goes beyond my needs.
So I thank you for your clarifying reply.
