Hello.
I'm working on a custom made robotic arm actuated by different motion controllers/motors via ros_canopen. Currently, the motors are controlled in profile position mode defined in the relevant yaml config file as follows:
robot_5s_arm_joint_controller:
  type: "position_controllers/JointTrajectoryController"
  joints:
    - joint_1
    - joint_2
    - joint_3
    - joint_4
    - joint_5
  required_drive_mode: 1
Due to some mechanical issues, i need to change the required_drive_mode to Interpolated position mode, but only three controllers (joint1-3) support this mode, the rest (joint4-5) can only be driven in profile position mode.
So the question is, what is the workaround here? :)
I suppose, that two arm_joint_controller groups shall be defined, one (joint1-3) with required_drive_mode: 7 and the other with required_drive_mode: 1. Then simply, in the moveit controller yaml file, i can define these controllers? Is this enough?
Do i need to change the planning group defined in moveit?
Thank you in advance.
Originally posted by akosodry on ROS Answers with karma: 121 on 2019-08-20
You can specify mixed modes
Much simpler: you can define a default mode (required_drive_mode, singular) and add a look-up (required_drive_modes, plural) for the others:
  joints:
    - joint_1
    - joint_2
    - joint_3
    - joint_4
    - joint_5
  required_drive_modes:
    joint_4: 1
    joint_5: 1
or you set all explicitly:
  joints:
    - joint_1
    - joint_2
    - joint_3
    - joint_4
    - joint_5
    joint_1: 7
    joint_2: 7
    joint_3: 7
    joint_4: 1
    joint_5: 1
Not needed.
Nope :)
Originally posted by Mathias Lüdtke with karma: 1596 on 2019-08-20
Comment by akosodry on 2019-08-20:
wow! THANKS!!!
