I'm trying to make a turtlebot like robot using only the RPLidar. Hence I donot have a good source for odometry. I'm getting the Pose2D using laser_scan_matcher, and can use the values and represent it in nav_msgs/Odometry.
I've also found a way to use these pose2D values with /scan headers to roughly calculate velocities.
But I want to know is it mandatory to have Twist information for move_base to work? Or does move_base only require Pose from the odometry messages?
Originally posted by parzival on ROS Answers with karma: 463 on 2019-08-19
Hi,
move_base doesn't require any odometry as per the diagram in the document (couldn't get the image link to work). However, it is the local_planner that requires information about your motion (specifically velocity so that it can extrapolate a dynamic path). I am unsure however, move_base might require a transform from base_link->odom->map. This should be done anyway if you have an odometry message and is definitely a pre-requisite before attempting navigation. Of course, the local planner is a part of move_base but I would segment it if you're implementing it so you can identify issues in a particular section.
Perhaps you could use robot_localization to provide this transform and give an odometry message after accounting for noise. I have never used laser_scan_matcher myself, however, perhaps you could use an Iterative Closest Point (ICP) estimate if you aren't happy with the results of the CSM estimate?
Originally posted by PapaG with karma: 161 on 2019-08-20
Comment by parzival on 2019-08-23:
Hi, yes robot_localisation should work too. I'm currently getting good results with laser_scan_matcher with a custom odometry node, so I'll continue playing around with that for a while. Thanks a lot! You've been great help!
Comment by pring on 2020-04-18:
@parvizal, could you provide a link to your custom odometry node? I take it you're taking odom from tf and converting it to nav_msgs/Odometry, using good-enough values for covariance? I'm doing exactly what you're doing (with an RPLidar as well :) ) and came to the same conclusion.
Edit: odom is only published in tf when you run the laser_scan_matching with gmapping demo :) So I suppose you're just using the PoseStamped msg and v=(x-x0)/dt to get twist, and publishing that ..
Wrote this up as a base but can't test yet due to broken robot :/
    pose = data.pose
    ts = data.header.stamp
    #https://answers.ros.org/question/69754/quaternion-transformations-in-python/
    euler = tf.transformations.euler_from_quaternion(pose.orientation)
    yaw = euler[2]
    # different method
    #odom->pose.pose.orientation.z = sin(yaw_/2.0)
    #odom->pose.pose.orientation.w = cos(yaw_/2.0)
    dx   = pose.position.x   - self.prev_x
    dy   = pose.position.y   - self.prev_y
    dyaw = pose.position.yaw - self.prev_yaw
    dt   = ts                - self.prev_ts
    odom = Odometry()
    #odom.header =
    #odom.child_frame_id =
    odom.pose.pose = pose
    odom.pose.covariance[0]  = 0.2 # x, covariances here are likely widely off
    odom.pose.covariance[7]  = 0.2 # y
    odom.pose.covariance[35] = 0.4 # yaw
    odom.twist.twist.linear.x    = dx/dt
    odom.twist.twist.linear.y    = dy/dt
    odom.twist.twist.angular.yaw = dyaw/dt
