I want to fuse global pose from tag pose estimation with visual odometry and IMU.
I am using:
- a RealSense D435i with realsense-ros that provides all the transformations between each sensor
- and rtab_map for the visual odometry
Fusing relative measurements (visual odometry and IMU) looks correct with rviz:
ekf_local.yaml
frequency: 30
sensor_timeout: 0.1
publish_tf: true
map_frame: map
odom_frame: odom
base_link_frame: camera_link
world_frame: odom
odom0: /odom
odom0_config: [true, true, true,
true, true, true,
true, true, true,
true, true, true,
true, true, true]
odom0_differential: false
odom0_relative: true
imu0: /imu/data
imu0_config: [false, false, false,
true, true, true,
true, true, true,
true, true, true]
imu0_differential: true
imu0_relative: false
imu0_remove_gravitational_acceleration: true
I am not able to fuse absolute pose with visual odometry and IMU. I want to use something like this:
ekf_global.yaml
frequency: 30
sensor_timeout: 0.1
publish_tf: true
map_frame: map
odom_frame: odom
world_frame: map
odom0: /odom
true, true, true,
true, true, true,
true, true, true,
true, true, true]
odom1: /tag_pose
odom1_config: [true, true, true,
true, true, true,
false, false, false]
odom1_differential: false
odom1_relative: false
imu0: /imu/data
true, true, true,
true, true, true,
true, true, true]
odom0
is the output of rtab_map
frame_id: "odom"
child_frame_id: "camera_link"
imu0
is:
frame_id: "camera_imu_optical_frame"
(Realsense ROS publishes all the transformations between the camera_link and for instance camera_imu_optical_frame.)
What should be the transformation for odom1
Is it the transformation between the map (frame_id) and the camera_link (so the raw transformation between the tag and the camera)? Is it the transformation between the map (frame_id) and the odom? Since I have another ekf_node that fuses the continuous data (vo and IMU), I can transform the raw tag pose.
The output of the local ekf is clear. It is the transformation between the odom and the camera_link. The odom frame is the initial position of the sensor when launching the nodes.
What is the output of the global ekf (/ekf_global/odometry/filtered
)? From the doc it should be the transformation between the map and odom. But from my understanding:
- map frame is fixed and corresponds in my case to the tag frame
- odom frame is the initial pose of the sensor and the transformation map / odom should be fixed
- camera_link is the free floating camera frame
So does the ekf (/ekf_global/odometry/filtered
) estimates the map --> odom transformation and I have to use the /ekf_local/odometry/filtered
to get the transformation between the tag/map and the camera_link?
Edit:
I did some tests, recapped here.
The homogeneous transformation a_T_b
means: X_a = a_T_b . X_b
The vision library detects the tag and estimates the transformation camlink_T_tag
. The goal was to still have the transformation camlink_T_tag
when the tag is not detected (occlusion, ...).
Option 1:
map
andtag
frames are the sameekf_local/odometry/filtered
estimatesodom_T_camlink
estimatesmap_T_camlink
- when the tag is detected, the transformation
map_T_camlink
is published - when the tag is not detected, you have to publish the transformation
map_T_camlink
using the fixed transformationmap_T_odom
is used to get the filtered tag pose- result
Option 2:
map
andodom
frames are the same, you have to publish a static identity transformmap_T_odom
- so both nodes (kind of) estimate the same transformation
map_T_camlink = map_T_tag . tag_T_camlink
is published withmap_T_tag
being a static transform computed at the first tag detection - there is nothing to publish when the tag is not detected since
map
andodom
are the same - but to have the transformation
camlink_T_tag
, you need the static transformtag_T_map
to be published - result
Option 3:
- filter only relative measurements
- when the tag is detected, you use the raw pose from the vision library
camlink_T_tag = camlink_T_odom . odom_T_tag
withodom_T_tag
being a static transformation that must be computed when the tag is detected and with the output ofekf_local/odometry/filtered
- result
I had not the time to test the three approaches on the same sequence, so this is just to have an idea.
Originally posted by cv_ros_user on ROS Answers with karma: 17 on 2019-08-08
