Hi there, I have a ROS Kinetic running Raspberry Pi 3 B (I have installed ros as a ROSberry installation, from the source as suggested), which runs Rosbridge Udp Server over it. I am getting in contact with it via a Windows-10 Laptop which has a c++ program running to send JSON's to the Raspberry Pi. When I send advertisement or subscription requests system runs perfectly, I am able to publish/receive messages and create topics easily. After I am done with the messaging, I want to unadvertise a topic (and unsubscribe) so that topic will be killed by ROS Master since there will be no subscribers or publishers left. I am sending the following JSON's to unsubscribe and unadvertise:
  • { "op": "unsubscribe", "id": "C-R", "topic": "top2" } //for unsubscribing
  • { "op": "unadvertise", "id": "yp2", "topic": "top2" } //for unadvertising
then I get the following warning, which says (I believe) I am asking ROS to unadvertise or unsubscribe, but I specifically added ID parts to the JSON's just to make sure that ROS understand the request is coming me and I am asking ROS to make me unadvertise and unsubscribe. Why am I having the warning and how can I fix this?
[WARN] [1564562740.474205]: Could not process inbound connection: [/rosbridge_udp] is not a publisher of [/top2]. Topics are [['/client_count', 'std_msgs/Int32'], ['/rosout', 'rosgraph_msgs/Log']]{'message_definition': 'string data\n', 'callerid': '/rosbridge_udp', 'tcp_nodelay': '0', 'md5sum': '992ce8a1687cec8c8bd883ec73ca41d1', 'topic': '/top2', 'type': 'std_msgs/String'} [WARN] [1564562741.499281]: Could not process inbound connection: [/rosbridge_udp] is not a publisher of [/top2]. Topics are [['/client_count', 'std_msgs/Int32'], ['/rosout', 'rosgraph_msgs/Log']]{'message_definition': 'string data\n', 'callerid': '/rosbridge_udp', 'tcp_nodelay': '0', 'md5sum': '992ce8a1687cec8c8bd883ec73ca41d1', 'topic': '/top2', 'type': 'std_msgs/String'} [WARN] [1564562743.519575]: Could not process inbound connection: [/rosbridge_udp] is not a publisher of [/top2]. Topics are [['/client_count', 'std_msgs/Int32'], ['/rosout', 'rosgraph_msgs/Log']]{'message_definition': 'string data\n', 'callerid': '/rosbridge_udp', 'tcp_nodelay': '0', 'md5sum': '992ce8a1687cec8c8bd883ec73ca41d1', 'topic': '/top2', 'type': 'std_msgs/String'}
Originally posted by mmp52 on ROS Answers with karma: 80 on 2019-07-31
See here: https://github.com/RobotWebTools/rosbridge_suite/issues/138
It seems like it is actually a bug in rospy (which rosbridge_suite is written in). Apparently unpublishing has been broken since 2013 (https://github.com/ros/ros_comm/issues/111). So the issue does not arise when your client unpublishes/unsubscribes from the rosbridge server, but when the rosbridge_server itself unpublishes the ros topic.
A workaournd is to set the unregister_timeout argument to a huge value. Like 1 year, so rosbridge_server never unpublishes any topics. If you are publishing/subscribing and unpublishing/unsubscribing from a lot of different topics, this might become a problem over time.
This situation is quite dissapointing in my opinion.
Originally posted by AndreasVH with karma: 36 on 2019-09-19
Comment by gvdhoorn on 2019-09-19:\
This may not count as an excuse, but rosbridge_suite, as with just about everything in ROS, is an OSS project. It will depend on volunteers and maintainers to get things fixed.
Unless someone spends some effort to fix this in rospy and submits that fix, nothing will change.
