Hi,
In ROS2 there are different types of logging handlers.
Command line arguments can be used to setup the loggers: these are passed to rclcpp::init() and then to rcl::init(). The command line arguments can do the following: enable stdout logging, enable rosout logging, enable an external logging library (log4cxx or spdlog). They do this by creating a logging_multiple_output_handler and setting it through rcutils_logging_set_output_handler.
I found myself in a situation where I want to use my own version of logging_multiple_output_handler. These handler should always use 2 loggers: rosout and an additional one that I'm defining.
For this reason, I created a function to be called right after rclcpp::init in order to re-initialize the logging handlers to what I need.
void set_ros2_logger_handler()
  auto allocator = rcl_get_default_allocator();
  rcl_logging_rosout_init(&allocator);
  auto logging_multiple_output_handler =
    const rcutils_log_location_t * location,
    int severity, const char * name, rcutils_time_point_value_t timestamp,
    const char * format, va_list * args) -> void
        rcl_logging_rosout_output_handler(location, severity, name, timestamp, format, args);
        my_custom_handler(location, severity, name, timestamp, format, args);
    rcutils_logging_set_output_handler(logging_multiple_output_handler);
However, this does not really work and I'm wondering what should be the best approach. The problems are the following:
  • rcl_logging_rosout_init is a hidden function (marked with RCL_LOCAL) so how can I know if rosout has been enabled without using it?
  • rcl_logging_rosout_output_handler is not declared as hidden, but still I can't link to it for some reason.
EDIT: apparently rcl_logging_rosout_output_handler should be accessible and the error is linked to the following line in rcl/CMakeLists.txt
rcl_set_symbol_visibility_hidden(${PROJECT_NAME} LANGUAGE "C")
TICKET: https://github.com/ros2/rcl/issues/476
DISCOURSE: https://discourse.ros.org/t/set-symbol-visibility-to-hidden-for-rmw-and-rcl-packages/7981/5?u=alsora
Originally posted by alsora on ROS Answers with karma: 1322 on 2019-07-29
The code I posted is supposed to work.
rcl_logging_rosout_output_handler is marked as RCL_PUBLIC, but it was not accessible due to a bug addressed by this PR https://github.com/ros2/rcl/pull/478
rcl_logging_rosout_init should be marked with RCL_PUBLIC too since otherwise the handler is useless. https://github.com/ros2/rcl/pull/479
Originally posted by alsora with karma: 1322 on 2019-08-01
