Is there support to use an external GPS with RTABmap_ros? I have seen previous answers saying this was not supported, but you could possibly use robot_localization to get around it (https://answers.ros.org/question/225694/interfacing-rtabmap-and-robot_localization/). However, according to (http://introlab.github.io/rtabmap/) version 0.14 of RTABmap Tango has GPS support. Has this feature been added to the ROS version yet?
Originally posted by kp12 on ROS Answers with karma: 3 on 2019-07-23
Hi,
Yes it is now available on ROS. It is mainly used for more robust graph optimization and loop closure detection. See this post: https://github.com/introlab/rtabmap/wiki/Robust-Graph-Optimization#multi-session
The input gps topic to rtabmap node is called /rtabmap/gps/fix, which is a sensor_msgs::NavSatFix type.
Note that rtabmap >=0.18.1 is required. Right now, only binaries in ROS melodic have the option (kinetic will be also updated soon), otherwise rtabmap should be built from source.
cheers,
Mathieu
Originally posted by matlabbe with karma: 6409 on 2019-07-24
Comment by PapaG on 2019-08-20:
Hi matlabbe, when are kinetic binaries expected to be updated?
Comment by matlabbe on 2019-08-21:
0.19.3 should be released in Kinetic: http://repositories.ros.org/status_page/ros_kinetic_default.html?q=rtabmap
Comment by carlostojal on 2022-10-17:
Hi. Checking noetic documentation I can't find references to any GPS topic. Was it deprecated? Thanks in advance.
Comment by matlabbe on 2022-10-23:
see https://github.com/introlab/rtabmap_ros/issues/828#issuecomment-1288193535
