In the "Writing a Simple Publisher and Subscriber (C++)" tutorial it states that in:
void chatterCallback(const std_msgs::String::ConstPtr& msg)
  ROS_INFO("I heard: [%s]", msg->data.c_str());
The message is passed in a boost shared_ptr, which means you can store it off if you want.
How exactly can I use this to store my data in a text file. I have no clue where to begin with this. I went through the boost shared_ptr documentation, but I do not understand it.
Originally posted by sw14928 on ROS Answers with karma: 3 on 2019-07-23
What speaks against doing a normal string write?
#include <fstream>
#include <string>
#include <iostream>
    std::ofstream out("output.txt");
    out << msg->data.c_str();
    out.close();
Originally posted by Mehdi. with karma: 3339 on 2019-07-23
Comment by sw14928 on 2019-07-23:
Thanks for your advice - it works, but how can I make it print a list? cheers
Comment by Mehdi. on 2019-07-23:
std::vectorstd::string str_vector; and then append msg->data.c_str() each time a message arrive then for loop on the vector and print the content
Sorry my C++ is not very good. Would that write my list to a vector, then how would I print that into my file iteratively? use append.msg?
