UPDATE I have aded 50 bounty for this question on the StackOverflow
I am trying to implement object tracking from the camera(just one camera, no Z info). Camera has 720*1280 resolution, but I usually rescale it to 360*640 for faster processing.
This tracking is done from the robots camera and I want a system which would be as robust as possible.
I will list what I did so far and what were the results.
- I tried to do colour tracking, I would convert image to hsv colour space, do thresholding, some morphological transformations and then find the object with the biggest area. This approach made a fair tracking of the object, unless there are no other object with the same colour. As I was looking for the max and if there are any other objects bigger than the one I need, robot would go towards the bigger one
- Then, I decided to track circled objects of the specific colour. However, it was difficult to find under different angles
- Then, I decided to track square objects of specific colour. I used this
// Approximate contour with accuracy proportional // to the contour perimeter cv::approxPolyDP( cv::Mat(contours[i]), approx, cv::arcLength(cv::Mat(contours[i]), true) * 0.02, true );
and then I checked this condition
if (approx.size() >= 4 && approx.size() <= 6)
and afterwards I checked for
solidity > 0.85 and aspect ratio between 0.85 and 1.15
But still result is not as robust as I would expect, especially the size. If there are several squares it would not find the needed one.
So, now I need some suggestions on what other features of the object could I use to improve tracking and how? As I mentioned above several times, one of the main problems is size. And I know the size of the object. However, I am not sure how I can make use of it, because I do not know the distance of the object from the camera and that is why I am not sure how to represent its size in pixel representation so that I can eliminate any other blobs that do not fall into that range.
UPDATE
In the third step, I described how I am going to detect squares with specific colour. Below are the examples of what I am getting.
I used this HSV range for the red colour:
Scalar(250, 129, 0), Scalar(255, 255, 255), params to OpenCV's inRange function
HMIN = 250, HMAX = 255; SMIN = 129, SMAX = 255; VMIN = 0, VMAX = 255; (Would like to see your suggestions on tweaking this values as well)
So, in this picture you can see the processing; gaussian blurring (5*5), morphological closing two times (5*5). And the image with the label "result" shows the tracked object (please look at the green square).
On the second frame, you can see that it cannot detect the "red square". The only main difference between these two pics is that I bended down the lid of the laptop (please look closer if you cannot notice). I suppose this happens because of the illumination, and this causes the thresholding to give not desired results.
The only way, I can think of is doing two separate processing on the image. First, to do thresholding based on the colour as I was doing above. Then if I find the object to move to the next frame. If not to use this opencv's find squares method.
However, this method will involve doing too much of processing of the image.
