I started to use ROS hydro (Robot Operating System) and roscpp. I tested some examples to move the gripper of pr2 in Gazebo (especially the code in : http://wiki.ros.org/pr2_gripper_sensor_action/Tutorials/Grab%20and%20Release%20an%20Object%20Using%20pr2_gripper_sensor_action ) with catkin package.
I launch : roslaunch pr2_gazebo pr2_empty_world.launch
and when I run the node of code with : rosrun pack_name node_name, I get :: Waiting for the r_gripper_sensor_controller/gripper_action action server to come up ... Waiting for the r_gripper_sensor_controller/gripper_action action server to come up ...
I want to know the cause of those lines in order to see the results. what should I do??
it is notable that when I launch : roslaunch pr2_gripper_sensor_action pr2_gripper_sensor_actions.launch
in the previous link, I get :
[pr2_gripper_sensor_actions.launch] is neither a launch file in package [pr2_gripper_sensor_action] nor is [pr2_gripper_sensor_action] a launch file name
    $\begingroup$ These messages indicate that some actionlib servers are not running. Can you post a list of running nodes and/or your launch scripts? $\endgroup$
    – Ben
    Feb 27 '16 at 2:05
  • $\begingroup$ ok. is it clear now?? $\endgroup$ Feb 27 '16 at 16:09
