I'm having an issue in my robot cell where the robot is sitting on the edge of a table and the table is outlined by four posts. running the robot to a random location in the center of the table I have about a 50 percent chance of the robot pathing through one of the posts close to it. image description
I've read through some of the moveit docs such as this http://docs.ros.org/melodic/api/moveit_tutorials/html/doc/ompl_interface/ompl_interface_tutorial.html and I've tried to play with "longest _valid_segment_fraction" for my planner. I don't know that I've seen any changes though. I've also tried to make the collision tags for each of the posts slightly larger so the sample checker has a higher probability of checking in collision but that hasn't helped either.
I guess my first question is how exactly do I use the "longest _valid_segment_fraction". my assumption was to place it inside the specific motion planner headder like the following.
  RRTConnect:
    type: geometric::RRTConnect
    range: 0.0  # Max motion added to tree.
    longest_valid_segment_fraction: 0.0005
are there any other ways of preventing the collisions?
Thanks
Originally posted by pathare on ROS Answers with karma: 28 on 2019-07-10
Comment by gvdhoorn on 2019-07-10:
I've closed your question as it violates the Support Guidelines. Specifically the request to not post screenshots of code/terminals or other kinds of text.
The RViz screenshot is fine, but please replace the screenshot of the .yaml file.
Copy-paste the contents into your question, select all of it and then press the Preformatted Text button (the one with 101010 on it).
You don't need to post a new question: just use the edit button/link to edit it.
Comment by pathare on 2019-07-10:
I fixed it but cant reopen it myself.
Comment by gvdhoorn on 2019-07-10:\
I would first check your collision geometry.
Does your cell have proper collision geometry specified?
Can you show a screenshot of RViz with the collision geometry enabled?
You were right, I forgot that I set an artificial ceiling so I didnt need to make collision objects for the upper rails. in the initial pose the robot was already in collision with the ceiling. I made the top rails like I should have done from the start and it works now.
This from gvdhoorn was the correct answer to my problem. Thanks
Originally posted by pathare with karma: 28 on 2019-07-10
