I have this script
#include "rclcpp/rclcpp.hpp"
using namespace std::chrono_literals;
class MinimalTimer : public rclcpp::Node
public:
  MinimalTimer()
  : Node("MinimalTimer")
    node_ = std::make_shared<rclcpp::Node>("test_node");
    node_->declare_parameter("parameter_A");
    auto timer_callback = [this]() -> void {
      RCLCPP_INFO(this->get_logger(), "Callback!");
    timer_ = this->create_wall_timer(500ms, timer_callback);
    this->declare_parameter("parameter_B");
private:
  rclcpp::TimerBase::SharedPtr timer_;
  std::shared_ptr<rclcpp::Node> node_;
int main(int argc, char * argv[])
  rclcpp::init(argc, argv);
  auto minimal_timer = std::make_shared<MinimalTimer>();
  rclcpp::spin(minimal_timer);
  rclcpp::shutdown();
  return 0;
and I ran ros2 run ....
ros2 node list gives
/MinimalTimer
/test_node
ros2 param list MinimalTimer gives
  parameter_B
  use_sim_time
but ros param list test_node hangs forever.
Any idea?
Originally posted by ahtsan on ROS Answers with karma: 112 on 2019-07-03
The example creates two nodes:MinimalTimer and test_node, but spins only one of them rclcpp::spin(minimal_timer);. rclcpp::spin() adds a node to an executor. The executor calls callbacks, like the parameter service callbacks. test_node must be added to an executor so the parameter service callbacks can send a response.
See the manual composition demo for an example.
rclcpp::executors::SingleThreadedExecutor exec;
exec.add_node(minimal_timer);
exec.add_node(minimal_timer->node_);
exec.spin();
Originally posted by sloretz with karma: 3061 on 2019-07-08
Comment by ahtsan on 2019-07-09:
Thank you!
