Hello, I am trying to set up an Extended Kalman Filter (EKF). I have the following types of sensors mounted on board of the ROV system:
UPDATES WITH SENSORS OUTPUT SAMPLES:
- IMU - Primarily used for Orientation
Sensor Output Sample:
header:
seq: 1900
stamp:
secs: 1517940907
nsecs: 527472019
frame_id: "base_link"
orientation:
x: -0.447962131618
y: 0.530470375983
z: -0.480721599498
w: -0.535572453192
orientation_covariance: [0.010000000000000002, 0.0, 0.0, 0.0, 0.010000000000000002, 0.0, 0.0, 0.0, 0.010000000000000002]
angular_velocity:
x: 0.00829399318143
y: -0.00832041039286
z: -0.0137973047577
angular_velocity_covariance: [0.1, 0.0, 0.0, 0.0, 0.1, 0.0, 0.0, 0.0, 0.1]
linear_acceleration:
x: 9.94429087323
y: -0.333990296188
z: 0.402224859015
linear_acceleration_covariance: [0.1, 0.0, 0.0, 0.0, 0.1, 0.0, 0.0, 0.0, 0.1]
- USBL- Sonar sensor that provides a global position (X,Y)
header:
seq: 19
stamp:
secs: 0
nsecs: 0
frame_id: "map"
child_frame_id: "base_link"
pose:
pose:
position:
x: 5.53904389031
y: 28.6836443911
z: 0.0
orientation:
x: 0.0
y: 0.0
z: 0.0
w: 0.0
covariance: [5.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 5.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 5.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
twist:
twist:
linear:
x: 0.0
y: 0.0
z: 0.0
angular:
x: 0.0
y: 0.0
z: 0.0
covariance: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
- Depth sensor (Z)
header:
seq: 1963
stamp:
secs: 1517941110
nsecs: 334011078
fluid_pressure: 54.99332428
variance: 6.93760519813e-310
- Camera odometry velocity (X,Y)
header:
seq: 0
stamp:
secs: 1517941154
nsecs: 288109779
frame_id: "camera"
child_frame_id: ''
pose:
pose:
position:
x: 0.0
y: 0.0
z: 0.0
orientation:
x: 0.0
y: 0.0
z: 0.0
w: 0.0
twist:
twist:
linear:
x: 0.0384064087279
y: 0.00654432723456
z: 0.0
angular:
x: 0.0
y: 0.0
z: 0.0
covariance: [0.000137899317246916, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 4.0039129564840004e-06, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
Last but not least I am also attaching the /tf
which is bouncing from odom->base_link
to map->odom
and I don't understand if this is correct:
transforms:
header:
seq: 0
stamp:
secs: 1517941485
nsecs: 531367064
frame_id: "map"
child_frame_id: "odom"
transform:
translation:
x: 0.0
y: 0.0
z: 0.0
rotation:
x: -0.000328594829182
y: -0.000809341203755
z: -0.000655427597093
w: 0.999999403703
transforms:
header:
seq: 0
stamp:
secs: 1517941486
nsecs: 31367064
frame_id: "odom"
transform:
translation:
x: 0.0
y: 0.0
z: 0.0
rotation:
x: 0.402161523997
y: -0.56568206831
z: 0.438444191176
w: 0.570996144849
In my case odom0
is considered my moving frame and I am trying to understand why my ROV is not updating its position with position messages.
odom0
is published confimed with rqt_topic
; world_frame instance of robot_localization has subscribed to odom0
and I confirmed that with rqt_graph
, additionally imu0
is subscribed and working properly.
I also used the debug option offered from robot_localization
<param name="debug" value="true"/>
<param name="debug_out_file" value="/home/to/Desktop/ekf_debug.txt"/>
And the output of this file clearly states that odom0
is never passed to the world frame, as a consequence of that the ROV is not moving. Below an image of what I am trying to achieve:
I don't understand what is happening. Below part of the debug file
dynamic_process_noise_covariance is false
print_diagnostics is true
Subscribed to /usbl/pose_projected (**odom0**)
odom0_differential is false
odom0_pose_rejection_threshold is 1.7977e+308
odom0_twist_rejection_threshold is 1.7977e+308
odom0_queue_size is 1
odom0 pose update vector is [t t f f f f f f f f f f f f f ]
odom0 twist update vector is [f f f f f f f f f f f f f f f ]
Subscribed to /imu/data_w_orientation (imu0)
imu0_differential is false
imu0_pose_rejection_threshold is 1.7977e+308
imu0_twist_rejection_threshold is 1.7977e+308
imu0_linear_acceleration_rejection_threshold is 1.7977e+308
imu0_remove_gravitational_acceleration is false
imu0_queue_size is 1
imu0 pose update vector is [f f f t t t f f f f f f f f f ]
imu0 twist update vector is [f f f f f f f f f f f f f f f ]
imu0 acceleration update vector is [f f f f f f f f f f f f f f f ]
------ RosFilter::integrateMeasurements ------
I am publishing the transformation in the following way:
import pyproj as proj
import rospy
import tf
import datetime
from geometry_msgs.msg import PoseWithCovarianceStamped
from sensor_msgs.msg import NavSatFix
from nav_msgs.msg import Odometry
from sensor_msgs.msg import Joy
class TransformPose:
def __init__(self):
self.pub = rospy.Publisher('/usbl/pose_projected', Odometry, queue_size=10)
self.pressed = False
rospy.Subscriber("/usbl/latitude_longitude", NavSatFix, self.callback)
def paramsReady(self):
return rospy.has_param('/utm_zone') and\
rospy.has_param('/origin_lon') and\
rospy.has_param('/origin_lat') and\
rospy.has_param('/origin_z')
def callback(self,data):
rospy.loginfo_once("received data lat lon usbl")
if(self.paramsReady()):
rospy.loginfo_once("Valid survey params found: transform_pose starting")
crs_wgs = proj.Proj(init='epsg:4326') # assuming you're using WGS84 geographic
utm_zone = rospy.get_param("/utm_zone")
crs_bng = proj.Proj(init=utm_zone) # use a locally appropriate projected CRS
originLon = rospy.get_param("/origin_lon")
originLat = rospy.get_param("/origin_lat")
# then cast your geographic coordinate pair to the projected system
xoff, yoff = proj.transform(crs_wgs, crs_bng, originLon, originLat)
zoff = rospy.get_param("/origin_z",0)
# input from NavSatFix
lon = data.longitude;
lat = data.latitude;
x, y = proj.transform(crs_wgs, crs_bng, lon, lat)
x = x-xoff
y = y-yoff
z = 0;
# output message
transformed_msg = Odometry()
transformed_msg.child_frame_id = "base_link"
if x== float('Inf') or y==float('Inf'):
pass
else:
transformed_msg.pose.pose.position.x=x
transformed_msg.pose.pose.position.y=y
transformed_msg.pose.pose.position.z=z
transformed_msg.header.frame_id="odom"
transformed_msg.pose.covariance = [5., 0., 0., 0., 0., 0.,
0., 5., 0., 0., 0., 0.,
0., 0., 5., 0., 0., 0.,
0., 0., 0., 0., 0., 0.,
0., 0., 0., 0., 0., 0.]
self.pub.publish(transformed_msg)
if self.pressed:
self.button_pub.publish(transformed_msg)
else:
rospy.loginfo_once("Receiving odom message but urvey params not ready. waiting...")
def joyCallback(self,joyMsg):
if(joyMsg.buttons[0]==1):
self.pressed = True
print("saving current location")
return
def main():
rospy.init_node('nav_projection_node')
transformer = TransformPose()
rospy.loginfo("starting")
rospy.spin()
main()
My launch file is the following:
<?xml version="1.0"?>
<launch>
<param name="use_sim_time" value="true" />
<node pkg="robot_localization" type="ekf_localization_node"
name="ekf_map" clear_params="false">
<param name="sensor_timeout" value="2.0"/>
<param name="two_d_mode" value="false"/>
<param name="map_frame" value="map"/>
<param name="odom_frame" value="odom"/>
<param name="base_link_frame" value="base_link"/>
<param name="world_frame" value="odom"/>
<param name="publish_tf" value="true"/>
<param name="frequency" value="10"/>
<param name="smooth_lagged_data" value="true"/>
<param name="debug_out_file" value="/home/emanuele/Desktop/ekf_debug.txt"/>
<param name="print_diagnostics" value ="true"/>
<param name="odom0" value="/usbl/pose_projected"/>
<rosparam param="odom0_config">[true, true, false,
false, false, false,
false, false, false]</rosparam>
<param name="odom0_differential" value="false"/>
<param name="odom0_nodelay" value="true"/>
<param name="odom0_relative" value="false"/>
<param name="imu0" value="/imu/data_w_orientation"/>
<rosparam param="imu0_config">[false, false, false,
true, true, true,
<param name="imu0_differential" value="false"/>
<param name="odom2" value="/cam/odometry"/>
<rosparam param="odom2_config">[false, false, false,
true, true, false,
<param name="odom2_differential" value="false"/>
</node>
<node pkg="rosbag" type="play" name="player" output="screen" args="--clock -q -s 2340 /home/test.bag"/>
<node pkg="ros_float" type="transform_pose.py" name="tras_pose" output="screen"/>
<!--Adding URDF model-->
<arg name="floatModel" default="$(find ros_float)/urdf/floatModel.urdf"/>
<arg name="gui" default="true" />
<param name="robot_description" command="$(find xacro)/xacro.py $(arg floatModel)" />
<param name="publish_frequency" value="1.0" />
<param name="use_gui" value="$(arg gui)"/>
<node name="joint_state_publisher" pkg="joint_state_publisher" type="joint_state_publisher" />
<node name="robot_state_publisher" pkg="robot_state_publisher" type="robot_state_publisher" />
</launch>
Originally posted by RayROS on ROS Answers with karma: 108 on 2019-06-28
Comment by Tom Moore on 2019-07-03:
Please provide a sample message from all sensor inputs.
Comment by RayROS on 2019-07-03:
Hello Tom and thanks for taking the time to read the question. I provided a print-screen of all the sensor involved both from rostopic echo /
and from rqt_topic
I hope that could be helpuf to figure out what the problem might be
Comment by gvdhoorn on 2019-07-03:
@RayROS: I'm sorry to have to do this, but I've closed your question as with your latest edit you're violating the support guidelines. Specifically: don't post screenshots of terminals / code / messages.
It's all text, so copy-paste whatever is needed into your question and use the Preformatted Text button (the one with 101010
on it) to format it properly. Use the edit
button/link to edit your question.
After you've fixed this, we can re-open.
@gvdhoorn, thanks for point that out. I just updated the sensor sample according to the guidelines. It should be correct now and sorry for adding the print-screen I thought it would have been easier to see it form there.
