When I was trying to configure the NDT mapping/matching algorithm, I clicked on the 'app' icon. But the terminal shows
(runtime_manager_dialog.py:18020): Gtk-WARNING **: Unable to show 'app': Operation not supported
Why is this?
My system: Ubuntu 16.04 ROS version: kinetic
Originally posted by Jasmine on ROS Answers with karma: 11 on 2019-06-26
Comment by amc-nu on 2019-06-26:
Can you please provide more details? Autoware version? (Commit) Are you using Docker?
Comment by Jasmine on 2019-06-27:
Hello, Thanks for replying. I am not using Docker, and btw, how do I check the Autoware version?
Comment by Josh Whitley on 2019-06-27:
If you downloaded the Autoware repo, go to that folder and run git status and post the output here. If you are using the latest version with the install instructions from https://gitlab.com/autowarefoundation/autoware.ai/autoware/wikis/Source-Build then go into your autoware workspace's source folder (~/autoware.ai/src) and into a main sub-folder (e.g. autoware/utilities) and run git status and post the output here.
On branch master Your branch is up-to-date with 'origin/master'. Changes not staged for commit: (use "git add ..." to update what will be committed) (use "git checkout -- ..." to discard changes in working directory)
modified:   ros/run
no changes added to commit (use "git add" and/or "git commit -a")
The output is like this.
Which folder did you do that in? Can you give me the full path to it? Also, can you do git fetch and then git status again?
I did this inside the folder /Autoware.
mist@mist-XPS-8930:~/Autoware$ git fetch remote: A repository for this project does not exist yet. fatal: repository 'https://gitlab.com/CPFL/Autoware.git/' not found mist@mist-XPS-8930:~/Autoware$ git status On branch master Your branch is up-to-date with 'origin/master'. Changes not staged for commit: (use "git add ..." to update what will be committed) (use "git checkout -- ..." to discard changes in working directory)
modified:   ros/run
You are on a very old version of Autoware. The Autoware project has changed URLs a few times but the proper URL for the current version is https://gitlab.com/autowarefoundation/autoware.ai/autoware. Previous URLs include:
If you have either of these, you will need to update your repository to point to the URL in the paragraph above. Please note that, as of version 1.12.0-alpha.1, the primary Autoware repository has been split up. You can find all new repositories at https://gitlab.com/autowarefoundation/autoware.ai. For install instructions for the latest version, see https://gitlab.com/autowarefoundation/autoware.ai/autoware/wikis/Installation. As 1.12 is not yet ready for release, these instructions do not include installation instructions for older versions - we are working on this. For now, you can do the following to get an older version:
cd ~
git clone https://gitlab.com/autowarefoundation/autoware.ai/autoware.git
cd autoware
git checkout 1.11.1 (or whatever version you want to go back to)
cd ros
For build instructions, see step 4 and below of https://gitlab.com/autowarefoundation/autoware.ai/autoware/wikis/Source-Build.
Originally posted by Josh Whitley with karma: 1766 on 2019-06-27
Comment by Jasmine on 2019-06-30:
Thanks so much.
