Hi.
I'm working a robot navigation using a lidar and 5 ultrasound sensors. using range_sensor_layer I couldn't get the robot to avoid obstacles within its range dont know if it's from the common costmap file, local or global. here are all of them, I really appreciate your help:
  1. costmap_common_params.yaml
 obstacle_range: 2.5
 raytrace_range: 3.5
 footprint: [[-0.200, -0.30], [-0.200, 0.300], [0.300, 0.300], [0.300, -0.300]]
 publish_frequency: 1.0
 map_type: costmap
 transform_tolerance: 0.2
 inflation_layer:
  inflation_radius: 0.5
  cost_scaling_factor: 0.8
 obstacle_layer:
   observation_sources: scan
   scan: {sensor_frame: rplidar, data_type: LaserScan, topic: scan, marking: true, clearing: true}
 range_sensor_layer:
   topics: ["range_1", "range_2", "range_3", "range_4", "range_5"]
   clear_threshold: 0.2
   mark_threshold: 0.80
  1. Global_costmap_params.yaml
  global_costmap:
      global_frame: map
      robot_base_frame: base_footprint
      update_frequency: 1.0
      static_map: true
      rolling_window: false
      transform_tolerance: 0.5
      plugins:
      - {name: static_layer,    type: "costmap_2d::StaticLayer"}
      - {name: obstacle_layer,  type: "costmap_2d::ObstacleLayer"}
      - {name: range_sensor_layer,   type: "range_sensor_layer::RangeSensorLayer"}
      - {name: inflation_layer, type: "costmap_2d::InflationLayer"}
      inflation_layer:
      range_sensor_layer:
        mark_threshold: 0.8
     obstacle_layer:
  1. local_costmap_params.yaml
  local_costmap:
    global_frame: odom
    update_frequency: 2
    static_map: false
    rolling_window: true
    width: 6
    height: 6
    resolution: 0.05
    transform_tolerance: 1.0
    plugins:
    inflation_layer:
    range_sensor_layer:
    obstacle_layer:
In this picture, the inflated area in the local map is detected by the lidar and I placed beers in front of each sonar sensors because their height be detected only by them and not the lidar. image description
update
Here are the messages right when I launch image description image description image description
Originally posted by Syrine on ROS Answers with karma: 57 on 2019-06-26
Comment by ahendrix on 2019-06-27:
When you visualize the ultrasound sensors in rviz, do they appear in the correct positions with the correct ranges?
(I've also increased your reputation, so you can post images now)
Comment by Syrine on 2019-06-27:
Thank you! The ranges do appear in their correct positions and their topics show correct ranges (min and max and even when I add an object). I can post images tomorrow when I get back to work
Comment by Humpelstilzchen on 2019-06-28:
Can you please add 1) the output of "rostopic echo -n 1 /range_1" 2) the output of move_base starting
Comment by ahendrix on 2019-06-29:
I don't really understand exactly what's wrong, but if this were my robot, I would try adjusting the ordering and the marking and clearing options on the range and obstacle layers.
Comment by Syrine on 2019-07-01:
Hi, Thank you both for replying. Here's the output of range_1
 header:
   seq: 1784
   stamp:
     secs: 324
     nsecs: 706000000
   frame_id: "sonar_1"
 radiation_type: 0
 field_of_view: 0.10000000149
 min_range: 0.019999999553
 max_range: 4.0
 range: 0.508712828159
I'm sorry I didn't get what you mean by move_base starting, there isn't such topic
@ahendrix I actually did that but nothing affected the sonar sensors
is there something to add in amcl or launch files?
Comment by Humpelstilzchen on 2019-07-01:
move_base is the node you load your configuration files (costmap_common_params.yaml, Global_costmap_params.yaml and local_costmap_params.yaml) in. When the node starts it should print a few lines to stdout.
There I added pictures right up, I hope they could help
This message in your output looks odd:
RangeSensorLayer: subscribed to topic /move_base/global_costmap/range_sensor_layer/range_1
That does not look like your range topic. It looks like the range topic is being given as a relative topic, instead of an absolute topic. I would try changing your range sensor topic config to:
range_sensor_layer:
  topics: ["/range_1", "/range_2", "/range_3", "/range_4", "/range_5"]
P.S. - Please copy and past terminal output instead of posting terminal screenshots. Copy and pasted text is easier to read and easier to search.
Originally posted by ahendrix with karma: 47576 on 2019-07-01
Comment by Syrine on 2019-07-02:
Thank you so much! I can't believe that was it. It worked only now I have this problem http://answers.ros.org/question/238312/range_sensor_layer-marks-max-sonar-range-as-obstacle/ I couldn't find the cpp file since i installed it using apt-get install ros-kinetic-range-sensor-layer in which there are only cmake files. So i'm using clear_on_max_rading:true
