Hello,
this question has been addressed in these questions as well (Q1, Q2), however no answer arrived, therefore i'm asking as well.
It is not clear from the wiki of ros_canopen that how does the node execute the homing of multiple motors/joints?
Do the motors execute the homing simultaneously or one-by-one?
If one-by-one, than does it mean, that the execution of the next homing procedure is not started until the previous has not been finished?
Also, is it possible to change the order of the sequence? I mean, what if i want to execute the homing like, joint1-joint3-joint2-joint4-joint5? Should be enough just to change the order in the yaml config file?
Thank you in advance.
Originally posted by akosodry on ROS Answers with karma: 121 on 2019-06-21
One-by-one (canopen_motor_node, as-is).
Exactly
Yes, just use list syntax to specify the overall order
Originally posted by Mathias Lüdtke with karma: 1596 on 2019-06-21
