If not, is there a way to declare a global parameter for all nodes?
Originally posted by ahtsan on ROS Answers with karma: 112 on 2019-06-20
Parameters are per node in ROS 2. There is no a global parameter server like ROS 1. It is possible to set a param on a node with ros2 param set
$ ros2 run demo_nodes_cpp parameter_blackboard &
$ ros2 param set /parameter_blackboard foo bar
Set parameter successful
$ ros2 param list /parameter_blackboard
  foo
  use_sim_time
If you'd like to set a parameter on all running nodes, you'll need to enumerate them and set the parameter on each one. If you would like to set a parameter on a lot of nodes that you're launching, the parameter should be passed into each launch_ros.actions.Node.
import launch
import launch_ros
    use_sim_time = launch.substitutions.LaunchConfiguration('use_sim_time', default=False)
    return launch.LaunchDescription(
            launch_ros.actions.Node(
                package='demo_nodes_cpp', node_executable='talker',
                node_name='talker',
                parameters=[{'use_sim_time': use_sim_time}]),
                package='demo_nodes_cpp', node_executable='listener',
                node_name='listener',
I used a LaunchConfiguration in this example. You can give it a value on the command line
$ ros2 launch example_launch.py use_sim_time:=True
$ ros2 param get /listener use_sim_time
Boolean value is: True
Originally posted by sloretz with karma: 3061 on 2019-06-20
Comment by ahtsan on 2019-06-20:
Perfect. Does ros2 param set /node_name key value trigger the on_parameter_event if a SyncParametersClient is defined inside the node? What I want to achieve is to perform some tasks if a parameter is true in the node.
I am answering to my own question: Yes, it does.
We can pass argument to set the parameter value for launch file. Is it possible when we run a standalone node? like ros2 run demo_nodes_cpp parameter_blackboard foo:=true.
Comment by marguedas on 2019-06-20:
It doesn't seem to be possible at the moment. But it is listed on the feature list for the next ROS 2 distribution: https://github.com/ros2/ros2/issues/734
passing key-value parameters on CLI
Can I use the same node for another rclcpp::SyncParametersclient? I have a node named foo_node running and do
void Foo::init()
  auto parameters_client = std::make_shared<rclcpp::SyncParametersClient>(this);
  this->declare_parameter("foo");
  auto sub = parameters_client->on_parameter_event(
    [this](const rcl_interfaces::msg::ParameterEvent::SharedPtr event) -> void
      for (auto & changed_param : event->changed_parameters)
        if (changed_param.name == "foo")
          RCLCPP_INFO(this->get_logger(), "Foo is set");
and when I run ros2 set param /foo_node foo true in another process, the callback is not triggered but instead it logs [INFO] [Logger]: Hey.
Any thoughts?
I am answering my self again: I have to make sure there is at least one reference to sub, otherwise it destroy itself.
