Dear all,
my problem is the following:
I want to save a rosbag file and dump at the same time the content of the parameter server on a file.
I want the file and the rosbag to have exactly the same time appendix. This is a similar problem to this but not quite the same because it doesn't involve setting the timestamps into parameter server values.
I couldn't find a way to save the timestamp string into an arg, however the following code kind of works for the parameters:
<launch>
  <arg name="time_now" value="`date +'%Y-%m-%d-%H-%M-%S'`" />
  <rosparam command="dump" param="/robot_description" file="robot_description_$(arg time_now).yaml" />
  <node name="rosbag" pkg="rosbag" type="record"
          args="-O robot_$(arg time_now).bag /chatter "/>
</launch>
The output says something like:
running rosparam dump robot_description_`date +'%Y-%m-%d-%H-%M-%S'`.yaml /robot_description
but the filename is correct.
However, when it comes to the rosbag part, the command is not understood, and in particular it believes +'%Y-%m-%d-%H-%M-%S' is a topic to log instead of the argument of date.
I know I could exploit the automatic appending of the string from rosbag, but there is a tiny chance the two string would be different.
I've tried to execute a fake node with a bash script inside that sets up an environment variable to be captured with $(env ...) but it didn't work out.
I've tried to use python and $(eval ...), but I couldn't get to work because I cant import and use time in the same line.
I understood that param are inaccessible from a launchfile (you can only set them but not get) unless you do dirty tricks with launch-prefix.
Is there another way (please don't tell me the only way is to create a Python script to run the rosbag)?
Originally posted by mcamurri on ROS Answers with karma: 102 on 2019-06-14
Comment by gvdhoorn on 2019-06-14:
I haven't really looked into this, but does this have to be started from a .launch file? A simple shellscript could do this easily (and shell scripts can be started from .launch files as well).
Comment by mcamurri on 2019-06-14:
you mean, calling the ROS commands (i.e., rosparam dump, rosbag, etc.) in a bash script and then calling the bash script from the launchfile? That might work but unfortunately it's a code shared among many people and I'm pretty sure they would not accept such change. Previously the launchfile simply had a fixed name for the yaml files and an appendix for the rosbag node.
I'm not sure if there are other constraints surrounding this, but one way is to make the time_now argument configurable on the command line:
<launch>
  <arg name="time_now" default="temp" />
</launch>
and then call it like so (I saved the above in a file called test.launch):
roslaunch test.launch time_now:=$(date +%Y-%m-%d-%H-%M-%S)
Originally posted by tryan with karma: 1421 on 2019-06-20
Comment by mcamurri on 2019-06-20:
This answer wins. Thanks!
