I'm using rqt_plot and having trouble. I noticed that there are a lot of these error messages generated when I'm trying to add a field to the plot:
$ ros2 run rqt_plot rqt_plot
  File "/opt/ros/crystal/lib/python3.6/site-packages/rqt_plot/plot_widget.py", line 256, in on_topic_edit_textChanged
    plottable, message = is_plottable(self._node, topic_name)
  File "/opt/ros/crystal/lib/python3.6/site-packages/rqt_plot/plot_widget.py", line 151, in is_plottable
    fields, message = get_plot_fields(node, topic_name)
  File "/opt/ros/crystal/lib/python3.6/site-packages/rqt_plot/plot_widget.py", line 135, in get_plot_fields
    slot_type, is_array, array_size = _parse_type(slot_type)
  File "/opt/ros/crystal/lib/python3.6/site-packages/rqt_plot/plot_widget.py", line 57, in _parse_type
    end_array_idx = topic_type_str.find(']', start=array_idx + 1)
TypeError: find() takes no keyword arguments
It seems that plot_widget.py expects topic_type_str to be of type string, but it's of type str instead. Am I missing some dependency? Thanks.
Originally posted by clyde on ROS Answers with karma: 1247 on 2019-05-14
I'm not sure that's the problem: str is what string (if you're talking about the ROS2 idl type) is mapped to afaik in Python clients.
The last line in the traceback shows this:
start is a "keyword argument" here. That is not supported. See this question on SO fi.
It seems to have been introduced in ros-visualization/rqt_plot#17 when rqt_plot was ported to ROS 2.
It looks like it's a copy-pasta or mistake (as it doesn't appear elsewhere in the file).
Submitted ros-visualization/rqt_plot#29 to remove the start there.
Originally posted by gvdhoorn with karma: 86574 on 2019-05-15
Comment by clyde on 2019-05-15:
Thanks for the response. I'll track the bug. Re: string, I was referring to the Python string module. But now I see that the string.find() method is not part of Python 3. So, a mis-formed question.
I patched locally, and found 2 more bugs. Submitted https://github.com/ros-visualization/rqt_plot/pull/30 with all 3 fixes.
Comment by gvdhoorn on 2019-05-15:
Ok.
Would've been nice to just base your PR on my commit, but nice to see things got fixed in the end.
Whoops, my git foo is still weak. I'll work on that next time. Thanks again.
