Hi, I'm working on a project in which I have to use SLAM and navigation for the robot. I want to know if it is possible to use SLAM for my virtual robot by moving in a Gazebo world , or is it mandatory to have the real robot (hardware) running around? Thank you
Originally posted by Syrine on ROS Answers with karma: 57 on 2019-05-09
You can definitely use Gazebo or any other simulator (e.g. Stage). The SLAM algorithm will be embedded into a node that requires streams of sensor data.
From the algorithm point of view there are no differences if these are coming from real sensors or "fake" ones from a simulator.
Here a tutorial with Gazebo and Gmapping SLAM algorithm http://wiki.ros.org/turtlebot_gazebo/Tutorials/indigo/Make%20a%20map%20and%20navigate%20with%20it
Originally posted by alsora with karma: 1322 on 2019-05-09
Comment by gvdhoorn on 2019-05-09:
While this comment is in general true (ie: due to the decoupling afforded by ROS a SLAM node should not care about whether it receives input from "real" or "virtual" sensors), there is one thing I've observed when using SLAM in simulated environments: real world environments are messy and highly unstructured. SLAM algorithms typically like that (lots of features, high saliency). Simulated environments (ie: models) might be too clean for a particular algorithm to work.
This will not affect all algorithms in the same way, but it may be something to keep in mind.
Comment by alsora on 2019-05-09:
Yes, agree 100%. If the user wants to test laser-based SLAM algorithm, an alternative to "clean models" consists in using as ground truth a map obtained from a different SLAM run, such as these ones http://www2.informatik.uni-freiburg.de/~stachnis/datasets.html or from the RADISH database https://dspace.mit.edu/handle/1721.1/62236
Comment by Syrine on 2019-05-09:
Hi, thank you all that is definitely helpful. And about gmapping on melodic, Since I'm a beginner I don't really know what it means to "build gmapping from source" as indicated in the following link https://answers.ros.org/question/296170/melodic-gmapping/ any help?? thanks
It's poor practice to ask follow-up questions in comments under accepted answers, but see whether #q300480 helps.
