Error content:
$ catkin_make
The program 'catkin_make' is currently not installed. You can install it by typing:
sudo apt install catkin
$ sudo apt install catkin
[sudo] password for developer:
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 catkin : Depends: python-catkin-pkg but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
I uninstalled and reinstalled ROS, but I get the same error.
The same problem occurred in the following three environments.
  1. Ubuntu 16.04 installed on desktop PC
  2. Ubuntu 16.04 installed on a laptop PC
  3. Ubuntu 16.04 installed on Windows 10 VMware
Any advice would be much appreciated.
Edit: Below is the installation guide.
http://wiki.ros.org/kinetic/Installation/Ubuntu
It will be an already installed message.
However, catkin_make will not be installed.
$ catkin_make
$ sudo apt install ros-kinetic-catkin
ros-kinetic-catkin is already the newest version (0.7.14-0xenial-20180809-132632-0800).
0 upgraded, 0 newly installed, 0 to remove and 69 not upgraded.
$ sudo apt-get install ros-kinetic-desktop-full
ros-kinetic-desktop-full is already the newest version (1.3.2-0xenial-20190320-232543-0800).
Originally posted by hiroshi_i_nakamura on ROS Answers with karma: 16 on 2019-05-06
Comment by gvdhoorn on 2019-05-06:\
Ubuntu is suggesting that because of the existence of upstream packages.
If you just want to install the "regular ROS packages", you'll want to install ros-kinetic-catkin, not catkin.
Can you tell us which installation guide / tutorial you've followed?
Comment by gvdhoorn on 2019-05-09:\
$ catkin_make
just making sure: did you do a source /opt/ros/kinetic/setup.bash before trying to run catkin_make?
That is needed as by default catkin_make will not be on the PATH.
Thank you for your help. When run after source /opt/ros/kinetic/setup.bash, catkin_make worked correctly.
Originally posted by hiroshi_i_nakamura with karma: 16 on 2019-05-09
