Hi! I am trying to subscribe to a laser scan of the hokuyo_node. (UTM-30LX)
I have checked that the rostopic(/scan) satisfied 40Hz.
$rostopic hz /scan
However, msg(/scan) callback is not satisfied 40Hz. (0.025sec)
Can I subscribe a rostopic(/scan) with 40Hz?
[ INFO] [1556028820.890011693]: 231]Laser 1.112000 0.117000 0.486000
[ INFO] [1556028820.890147465]: 232]Laser 1.113000 0.119000 0.485000
[ INFO] [1556028820.933906513]: 233]Laser 1.118000 0.120000 0.488000
[ INFO] [1556028820.934033465]: 234]Laser 1.114000 0.128000 0.486000
[ INFO] [1556028820.977954391]: 235]Laser 1.112000 0.109000 0.488000
[ INFO] [1556028820.978087813]: 236]Laser 1.112000 0.117000 0.493000
[ INFO] [1556028821.021961768]: 237]Laser 1.113000 0.110000 0.492000
[ INFO] [1556028821.027527888]: 238]Laser 1.116000 0.116000 0.487000
[ INFO] [1556028821.070109309]: 239]Laser 1.113000 0.128000 0.486000
I using a source code below.
#include <ros/ros.h>
#include <sensor_msgs/LaserScan.h>
void laserCallback(const sensor_msgs::LaserScan::ConstPtr & scan)
    ROS_INFO("%d]Laser %f %f %f", scan->header.seq, scan->ranges[0], scan->ranges[360], scan->ranges[719]);
    ros::init(argc, argv, "laser_scan");
    ros::NodeHandle nh;
    ros::Subscriber scan_sub = nh.subscribe("/scan", 1000, laserCallback);
    ros::spin();
    return 0;
Originally posted by Gspark on ROS Answers with karma: 33 on 2019-04-23
Comment by gvdhoorn on 2019-04-23:
Please do not post screenshots of terminals, there is no need. It's all text, so copy-paste the console text into your question. Then use the Preformatted Text button (the one with 101010 on it) to properly format it.
I'm slightly confused by your statements, but if you mean that rostopic hz .. prints that the topic is publishing at 40 Hz but your callback doesn't appear to be receiving messages at 40 Hz, then you might want to look into setting the tcpNoDelay transport hint (docs).
Originally posted by gvdhoorn with karma: 86574 on 2019-04-23
Comment by Gspark on 2019-04-23:
@gvdhoorn Correct! I prints that the topic is publishing at 40 Hz but callback didn't appear to be receiving messages at 40 Hz. It was solved with your advice. thank you.
ros::Subscriber sub = nh.subscribe("/scan", 1000, laserCallback, ros::TransportHints().tcpNoDelay());
ps. How I select your comment for best answer?
