Hello,
at the moment I am developing an Android application that publishes data into a ROS environment. For this, I use rosandroid-core which is included with Maven from the following repository: https://github.com/rosjava/rosjava_mvn_repo.
By commands like
compile 'org.ros.rosjava_messages:std_msgs:0.5.11'
I am able to generate all standard messages that are defined in the repository. The String-message is defined like the following:
package std_msgs;
import org.ros.internal.message.Message;
public interface String extends Message {
public static final String _DEFINITION = "string data\n";
public static final String _TYPE = "std_msgs/String";
String getData();
void setData(String str);
Now I want to create my own message type. So I created a Java interfaces that extends the org.ros.internal.message.Message class.
When I initalize a message from the custom type in the code, everything is fine. But as soon as I want to publish a message from this custom message type, I get a NoClassFoundException.
Do you know where the error is? How can I include the compilation of my custom message type in the Gradle file?
Thanks and best regards.
Originally posted by MrNicolas3003 on ROS Answers with karma: 11 on 2019-04-20
Hi!
That's not how ROS messages work in Java. Note that those interfaces are just empty placeholders; the actual objects that you use to exchange data are generated in runtime.
Those interfaces are generated automatically if you source genjava when building inside a catkin workspace. The standard ROS tutorial to create messages applies.
You can check rosjava_messages repository for reference. It should help you creating custom messages. If you want to use the messages in Android Studio:
  • Create a ROS package with message definitions in your workspace. Configure your CMakeLists file to generate the workspace.
  • Generate the message artifacts by building the workspace. You will need to have genjava installed.
  • Source the workspace.
  • Launch Android Studio. The Maven paths will enable the IDE to find the artifacts you've just generated in the step above.
Hope it helps!
Extra: I don't have a complete example at hand for messages, but generating service interfaces is analogous. You can check how it's done for services here: https://github.com/jubeira/rosjava_srv_test
Originally posted by jubeira with karma: 1054 on 2019-04-22
Comment by MrNicolas3003 on 2019-04-23:
Hello,
thank you for your fast answer! Is there also a way to generate custom ROS messages in Java without a ROS environment?
Comment by jubeira on 2019-04-23:
Hmm not that I know of nor I would recommend... In any case you'll need genjava to translate the msg files to the interfaces.
Comment by MrNicolas3003 on 2019-04-24:
Okay, I am going to install a ROS environment. Thank you very much!
