I know this question has been asked a number of times, and I've gone through and followed the instructions on a number of those answers (for example- here and here), as well as in the documentation for building a custom message. Yet still my message header is not building.
This is the error I get:
/home/erinline/Documents/testsim/src/m-explore/explore/src/explore.cpp:39:10: fatal error: msg/util.h: No such file or directory
#include <msg/util.h>
compilation terminated.
m-explore/explore/CMakeFiles/explore.dir/build.make:86: recipe for target 'm-explore/explore/CMakeFiles/explore.dir/src/explore.cpp.o' failed
make[2]: *** [m-explore/explore/CMakeFiles/explore.dir/src/explore.cpp.o] Error 1
CMakeFiles/Makefile2:23711: recipe for target 'm-explore/explore/CMakeFiles/explore.dir/all' failed
make[1]: *** [m-explore/explore/CMakeFiles/explore.dir/all] Error 2
Makefile:140: recipe for target 'all' failed
make: *** [all] Error 2
Invoking "make -j4 -l4" failed
This is my CMakeLists.txt:
project(explore_lite)
## Find catkin macros and libraries
  actionlib
  actionlib_msgs
  costmap_2d
  geometry_msgs
  map_msgs
  move_base_msgs
  nav_msgs
  roscpp
  std_msgs
  tf
  visualization_msgs
  message_generation
add_message_files(
  FILES
  util.msg
generate_messages(
  DEPENDENCIES
  std_msgs
## catkin specific configuration ##
catkin_package(
  CATKIN_DEPENDS
    actionlib_msgs
    geometry_msgs
    map_msgs
    move_base_msgs
    nav_msgs
    std_msgs
    visualization_msgs
    message_runtime
## Build ##
# c++11 support required
include(CheckCXXCompilerFlag)
check_cxx_compiler_flag("-std=c++11" COMPILER_SUPPORTS_CXX11)
if(COMPILER_SUPPORTS_CXX11)
  set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++11")
else()
  message(FATAL_ERROR "The compiler ${CMAKE_CXX_COMPILER} has no C++11 support. Please use a different C++ compiler.")
endif()
## Specify additional locations of header files
include_directories(
  ${catkin_INCLUDE_DIRS}
  include
add_executable(explore
  src/costmap_client.cpp
  src/explore.cpp
  src/frontier_search.cpp
#add_dependencies(explore ${${PROJECT_NAME}_EXPORTED_TARGETS} ${catkin_EXPORTED_TARGETS})
add_dependencies(explore explore_lite_generate_messages_cpp)
target_link_libraries(explore ${catkin_LIBRARIES})
## Install ##
# install nodes
install(TARGETS explore
  ARCHIVE DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
  LIBRARY DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
  RUNTIME DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
# install roslaunch files
install(DIRECTORY launch/
  DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION}/launch
## Testing ##
if(CATKIN_ENABLE_TESTING)
  find_package(roslaunch REQUIRED)
  # test all launch files
  roslaunch_add_file_check(launch)
endif()
My message is called util.msg, it is in a file called msg within the package file called explore. I must be missing something, since those previous answers seem to work for some folks. Any advice on where I am going wrong would be greatly appreciated!
Originally posted by kitkatme on ROS Answers with karma: 47 on 2019-04-13
Your CMakeLists.txt shows:
add_message_files(
  FILES
  util.msg
The error output shows:
You write:
My message is called util.msg, it is in a file called msg within the package file called explore [..]
There are a few discrepancies here:
  • according to your build script, the package is actually called explore_lite, not explore
  • the compiler output suggests it's in a directory called m-explore (or the package is actually called m-explore)
As to why the include fails: message header #include lines follow the pattern: pkg_that_hosts_the_msg/MsgHeader.h.
In your care this should probably be explore_lite/util.h, not msg/util.h.
Two additional comments:
  1. it might be good to store messages in a separate package (it will make interfacing with your package much easier, as I don't have to build your node in order to use the messages)
  2. try to follow ROS naming guidelines: util as a name does not convey much semantics and message (file)names should start with an uppercase character
Originally posted by gvdhoorn with karma: 86574 on 2019-04-14
Comment by kitkatme on 2019-04-14:
thanks so much!! your suggestion to change the include line to explore_lite/util.h solved the issue. also thanks for the notes on guidelines! will update my files later.
