I'm developing a robotic hand, and decided to place motors inside joints (as in picture) and I'm stuck with finding a stepper motor that can fit there. Approximate size of motor body is radius - 10mm, length - 10 mm.
Any suggestions?
Robotics Stack Exchange is a question and answer site for professional robotic engineers, hobbyists, researchers and students. It only takes a minute to sign up.
Sign up to join this communityI'm developing a robotic hand, and decided to place motors inside joints (as in picture) and I'm stuck with finding a stepper motor that can fit there. Approximate size of motor body is radius - 10mm, length - 10 mm.
Any suggestions?
I have used MicroMo's stepper motors in the past. You can find their information here: http://www.micromo.com/products/stepper-motors/stepper-motors-datasheets
However, I don't know if a design process of "make decisions then see what fits" is the best approach. You should determine the performance you need, then look for components, and base your architectural decision on what you find available. You may need to relocate the motors and use some kind of mechanical transmission to get the hand performance you're looking for. It is hard to say with such little required performance information.
