Hello,
I'm working on Jackal from Clearpath. The robot came with indigo and after a while, I re-imaged it. Now everything is working fine except LiDAR. When I run rostopic list
it doesn't show /front/scan
in a list. It was showing it before re-imaged the robot.
for running the LiDAR I follow these steps:
sudo apt-get install ros-indigo-lms1xx
cd /opt/ros/indigo/share/lms1xx/launch
sudo cp LMS1xx.launch /etc/ros/indigo/ros.d/
After the above steps I connected the robot to Access Point since our university lab has some IT restriction and it doesn't let me access the robot with SSH.
Immediately after re-imaging the robot the rostopic list
shows the /front/scan
but when I run rostopic echo /front/scan
didn't show any update. I did somthing and it got even worth which dosn't show in rostopic list output.
I connect to the robot with my cellphone hot spot the IPs are :
Robot IP: 192.168.43.140
Host IP: 192.168.43.113
and run the LMS1xx.launch
and below are the outputs:
administrator@PNW-ECE:/opt/ros/indigo/share/lms1xx/launch$ ls
LMS1xx.launch
administrator@PNW-ECE:/opt/ros/indigo/share/lms1xx/launch$ roslaunch LMS1xx.launch
... logging to /home/administrator/.ros/log/40850f36-4830-11e9-82ab-59833ebd9fa1/roslaunch-PNW-ECE-25769.log
Press Ctrl-C to interrupt
started roslaunch server http://192.168.43.140:52473/
SUMMARY
PARAMETERS
* /lms1xx/host: 192.168.1.14
* /rosdistro: indigo
* /rosversion: 1.11.21
NODES
lms1xx (lms1xx/LMS1xx_node)
ROS_MASTER_URI=http://192.168.43.140:11311
core service [/rosout] found
process[lms1xx-1]: started with pid [25799]
I also don't know how can I activate the Lidar node. It seems the node is not activated yet.
Any Help would be appreciated.
Thank you
Update: When I run below command in one terminal, I can see the /front/scan in my rostopic list in another terminal.
roslaunch jackal_navigation gmapping_demo.launch
but still I can't see the output of the lidar.
Originally posted by imanpakii on ROS Answers with karma: 26 on 2019-03-17
Comment by ahendrix on 2019-03-19:
I don't know anything about this particular ROS node, but I would try to get it working with rosrun
before trying to set up launch files for autostart.
Comment by mgruhler on 2019-03-20:
maybe some more information about what exactly you did do when you "re-imaged" it might also be helpful. Did you use a provided image? Did you manually install stuff? ...
Comment by imanpakii on 2019-03-20:
Hi
Thank you for your response. I re-imaged with the provided image from clearpath, and I install Lidar stuff myself.
Thank you
Comment by mgruhler on 2019-03-21:
just a few pointers, but I'm lost about what could be your issue:
- check that the IP of the LMS is actually 192.168.1.14
- why do you think you have to activate the lidar? The driver should do this for you, if the connection is right...
- what's that thing with your cellphone hotspot? You are running all those commands on the robot PC itself (connected via ssh), correct?
Comment by imanpakii on 2019-03-21:
Hello @mgruhler
1-Thank you for your response. I checked it with SICK LIDAR software and also when I ping it, it response me back. when I disconnect it, the ping is not working.
2- because when I run rostopic list
it does not appear to the list. but when I run for example roslaunch jackal_navigation gmapping_demo.launch
and in another terminal do the rostopic list
topic in a list. that's why I think it's not activated.
3- yes I do, but because our university lab has some restrictions in terms of security, the SSH connection doesn't work correctly all the time and also the IP address always change and we need to connect the cable to the robot for obtaining the IP address. That's why We set up an Access point, and if I want to download any packages in the robot I can't do that with AP then I connect my robot and my PC through my cell hot spot together.
Thank you for your help Iman
Comment by billy on 2019-03-21:
Just a thought I have when I see reports of things working and not working regarding topics. If you're starting and stopping nodes, makes sure that you have roscore running when you start a node. If you kill roscore and restart it, it will lose track of nodes that were running until they have been restarted as well.
Comment by imanpakii on 2019-03-22:
Hello,
I think the roscore
is working since another rostopic
working properly. for example odometry or IMU or camera, they appear in rostopic list
and also when I do the rostopic echo <topic>
they are showing the raw data.
Thank you
Comment by ahendrix on 2019-03-24:
Does the lidar node work if you run it manually with rosrun: rosrun lms1xx LMS1xx_node _host:=192.168.1.14
Comment by imanpakii on 2019-03-24:
Hello,
Thank you for your comment. I can check it tomorrow when I go to lab, but what will it can tell us if it's work or not? Thank you
You may get an error message indicating that it wasn't able to connect, or a message saying that it did, or it may crash. It may also print the topic that it's publishing to. In any of those cases, I'm hoping that it helps you figure out whether the issue is your hardware, a software issues, or a configuration problem.
Comment by gvdhoorn on 2019-03-25:
@imanpakii: could you please not edit your post just to bump it? The last two edits don't seem to actually add anything to your post.
Comment by imanpakii on 2019-03-27:
@ahendrix
Hello,
Please see the output below:
[ INFO] [1553638617.627167916]: Connecting to laser at 192.168.1.14
[ INFO] [1553638617.642444928]: Connected to laser.
I also run the below command as well:
echo /front/scan
WARNING: topic [/front/scan] does not appear to be published yet
Thank you Iman
Comment by mgruhler on 2019-03-27:
If you just rosrun
this node, it will publish the topic to /scan
. This is actually what the launch file is doing as well. There is no remapping in there. Could it be that the driver is working all along, publishing to /scan
and /front/scan
is showing up because something is subscribing to that?
To confirm, run the following commands:
rostopic info /scan
rostopic info /front/scan
rosnode info /lms1xx
