Hello,
I’m using panda arm with moveit. I want to create the planning group which will include all the joints in my robot. Currently i have created two planning groups as suggested in this tutorial.
When i simply add all joints in one planning group i get error of group is not a chain, no kinmetic solver is instantiated for this group.
I want to plan trajectory for whole panda robot i.e. arm and gripper together. I tried various ways such as
- adding all joints in a group
- adding chain which includes base and tip links etc
I have referred this and this previous questions too, but i couldn’t come up with a planning group which will let me plan trajectory for whole panda robot.
Can anyone suggest me why the planning group including all the joints gives me error which can be seen below?? and how can i rectify it??
Update 1
Here is the main URDF file, which includes arm and hand xacro files.
Here is the SRDF file (created when i include all the joints of panda robot in one planning group)
Relevant Error lines from terminal
You can start planning now!
[ INFO] [1552464458.084260463]: Loading robot model 'panda'...
[ WARN] [1552464458.084320265]: Skipping virtual joint 'virtual_joint' because its child frame 'panda_link0' does not match the URDF frame 'world'
[ INFO] [1552464458.084338894]: No root/virtual joint specified in SRDF. Assuming fixed joint
[ INFO] [1552464458.159456831]: Loading robot model 'panda'...
[ WARN] [1552464458.159490871]: Skipping virtual joint 'virtual_joint' because its child frame 'panda_link0' does not match the URDF frame 'world'
[ INFO] [1552464458.159505494]: No root/virtual joint specified in SRDF. Assuming fixed joint
[ERROR] [1552464458.162638812]: Group 'panda_arm' is not a chain
[ERROR] [1552464458.162676424]: failed to initialized caching plugin
[ERROR] [1552464458.162696757]: Kinematics solver of type 'cached_ik_kinematics_plugin/CachedKDLKinematicsPlugin' could not be initialized for group 'panda_arm'
[ERROR] [1552464458.162950656]: Kinematics solver could not be instantiated for joint group panda_arm.
[ INFO] [1552464458.209491415]: Starting scene monitor
[ INFO] [1552464458.222512226]: Listening to '/move_group/monitored_planning_scene'
[ INFO] [1552464458.727591546]: No active joints or end effectors found for group 'hand'. Make sure that kinematics.yaml is loaded in this node's namespace.
[ INFO] [1552464458.728529359]: No active joints or end effectors found for group 'hand'. Make sure that kinematics.yaml is loaded in this node's namespace.
[ INFO] [1552464458.728837948]: Constructing new MoveGroup connection for group 'hand' in namespace ''
[ INFO] [1552464459.725851190]: Ready to take commands for planning group hand.
[ INFO] [1552464459.726127065]: Looking around: no
[ INFO] [1552464459.726254093]: Replanning: no
Originally posted by mvish7 on ROS Answers with karma: 104 on 2019-03-12
Comment by fvd on 2019-03-13:
You should post the SRDF and URDF you are using as well as the error message
To clarify: The guide to create a trajectory with MoveIt is in the tutorials. This is a Q&A site, so you need to post a question that can have a meaningful answer. "Can someone help me?" is not a question that can be answered in this format. By contrast, "Why is this thing that I tried not working?" can be answered.
Comment by mvish7 on 2019-03-13:
@fvd: Apologies for inappropriate framing of my question. You are right and i don't expect to get full fledged guidance on this forum but only hints on what's going wrong?
Could you please have a look at the update part of the question??
If there is any tutorial available on planning trajectory for arm + gripper, can you please point me that resource??
