Hello, I’m trying to achieve pick and place in gazebo for panda arm by using moveit+rviz to plan motion. I’m getting below error on the terminal from which i launch moveit_planning _execution.launch file.
Controller panda/panda_hand_controller failed with error code INVALID_JOINTS
here is my config/controllers.yaml file from moveit side
controller_manager_ns: controller_manager
controller_list:
- name: panda/panda_arm_controller
action_ns: follow_joint_trajectory
type: FollowJointTrajectory
default: true
joints:
- panda_joint1
- panda_joint2
- panda_joint3
- panda_joint4
- panda_joint5
- panda_joint6
- panda_joint7
- name: panda/panda_hand_controller
default: true
joints:
- panda_finger_joint1
- panda_finger_joint2
Below is my joint_names.yaml file
controller_joint_names: ['panda_joint1', 'panda_joint2', 'panda_joint3', 'panda_joint4', 'panda_joint5', 'panda_joint6', 'panda_joint7', ’panda_finger_joint1’, ’panda_finger_joint2’]
About moveit planning groups from setup assistant tool, below are the groups i have created. I’m using panda_arm as planning group in my code
Can someone tell me how to solve or debug this issue?
Update 1
On the terminal from which i spawn gazebo and controllers i get below error
Joints on incoming goal don't match the controller joints.
My suspect is that these errors are occurring because of following reason
I’m using "panda_arm " as planning group which doesn’t include finger_joints (in this case i’m doing as suggested in moveit_tutorial. ) Here can anyone suggest me how planning group should be in moveit setup_assistant?
Update 2
In gazebo, robot approaches the object and when it should open the finger joints( comparing to fake trajectory execution in rviz) robot stops the trajectory execution.
Originally posted by mvish7 on ROS Answers with karma: 104 on 2019-03-11
Comment by lab.engineering on 2019-03-11:
Hey - I think we have the same problem, Running moveit+rviz with the Pandas current ros-melodic-franka-description.
When you run the standard demo.launch do you get a Clump of Panda joints in the center of your workspace?
Screenshot of MoveIt
I've followed the setup assistant and tried making a couple other joint configurations - but nothing yet. : Setup_assistant_tutorial
Could it be from the latest melodic-franka-description?
Comment by gvdhoorn on 2019-03-11:
@lab.engineering: it's much more likely you're running into #q272692.
Comment by mvish7 on 2019-03-11:
@lab.engineering: For me everything works fine in RVIZ. Even with demo.launch i'm able to see pick and place happening in RVIZ. i have problem in gazebo that panda arm reaches till the pose where it should open up the finger joints but finger_joints are not moving.
@gvdhoorn: any suggestions on this issue by looking at update 2??
