Hi,
i wrote launch file which use some different packages and i want to do one file which contains folders with this packages and folder "launch", where this launch file exist (3 folders with packages + 1 folder with launch files). I cant run this launch file cause i got error:
RLException: [allTags.launch] is neither a launch file in package [tag_detector_ros] nor is [tag_detector_ros] a launch file name
The traceback for the exception was written to the log file
I was trying with catkin_make and source devel/setup.bash. Can someone tell me how can I do it correctly?
LaunchFile:
<launch>
 <arg name="tag" default="1" />
 <group if="$(eval tag == 1)">
 <include file="$(find package_name)/launch/launch_file_name.launch"/>
 </group>
<group if="$(eval tag == 2)">
</group>
</launch>
output of rospack find tag_detector_ros:
[rospack] Error: package 'tag_detector_ros' not found
output of find $(rospack find tag_detector_ros) -name *.launch:
./src/image_pipeline/stereo_image_proc/launch/stereo_image_proc.launch
./src/image_pipeline/image_proc/launch/image_proc.launch
./src/usb_cam/launch/usb_cam-test.launch
./src/tag_detector_ros/aruco_ros/aruco_ros/launch/aruco_marker_finder_kinect.launch
./src/tag_detector_ros/aruco_ros/aruco_ros/launch/double.launch
./src/tag_detector_ros/aruco_ros/aruco_ros/launch/marker_publisher.launch
./src/tag_detector_ros/apriltags2_ros/apriltags2_ros/launch/continuous_detection.launch
./src/tag_detector_ros/apriltags2_ros/apriltags2_ros/launch/single_image_client.launch
./src/tag_detector_ros/apriltags2_ros/apriltags2_ros/launch/single_image_server.launch
./src/tag_detector_ros/launch/allTagsTogether.launch
./src/tag_detector_ros/launch/allTags.launch
./src/tag_detector_ros/vision_visp/visp_auto_tracker/launch/tracklive_usb.launch
./src/tag_detector_ros/vision_visp/visp_auto_tracker/launch/tracklive_usb_dataMatrix.launch
./src/tag_detector_ros/vision_visp/visp_auto_tracker/launch/tracklive_firewire.launch
./src/tag_detector_ros/vision_visp/visp_auto_tracker/launch/tutorial.launch
./src/tag_detector_ros/vision_visp/visp_camera_calibration/launch/lagadic_grid.launch
./src/tag_detector_ros/vision_visp/visp_tracker/launch/start.launch
./src/tag_detector_ros/vision_visp/visp_tracker/launch/flea2/config.launch
./src/tag_detector_ros/vision_visp/visp_tracker/launch/flea2/camera-nodelet.launch
./src/tag_detector_ros/vision_visp/visp_tracker/launch/hrp2014/config.launch
./src/tag_detector_ros/vision_visp/visp_tracker/launch/hrp2014/camera.launch
./src/tag_detector_ros/vision_visp/visp_tracker/launch/hrp2014/camera-nodelet.launch
./src/tag_detector_ros/vision_visp/visp_tracker/launch/hrp2014/image_pipeline.launch
./src/tag_detector_ros/vision_visp/visp_tracker/launch/tutorial-multi.launch
./src/tag_detector_ros/vision_visp/visp_tracker/launch/tutorial-nodelet.launch
./src/tag_detector_ros/vision_visp/visp_tracker/launch/tutorial.launch
./src/tag_detector_ros/vision_visp/visp_tracker/launch/uvc/config.launch
./src/tag_detector_ros/vision_visp/visp_tracker/launch/uvc/camera-nodelet.launch
Originally posted by Filip4 on ROS Answers with karma: 13 on 2019-03-06
Comment by gvdhoorn on 2019-03-06:\
WIthout seeing the launchfile? No.
Comment by Filip4 on 2019-03-06:
Just a simple launchfile with including others launchfile (from this additional packages). Even if launch file is empty error occurs. Added launchfile code on main post.
Please also show us the exact steps you perform (building workspace, sourcing it and invoking roslaunch).
catkin_make -> source devel/setup.bash -> roslaunch package_name launch_file_name
That is paraphrasing. Exact commands mean: copy-paste.
catkin_make, source devel/setup.bash, roslaunch tag_detector_ros allTags.launch
Comment by gvdhoorn on 2019-03-07:
What is the output of rospack find tag_detector_ros and find $(rospack find tag_detector_ros) -name *.launch?
Comment by Filip4 on 2019-03-07:
Added on main post
well it would seem that 'tag_detector_ros' is just not a package in your workspace, and looking at the output of the find command, it would appear to actually be a directory, containing other ROS pkgs (ie: aruco_ros, apriltags2_ros, visp_auto_tracker, etc).
roslaunch can only launch launchfiles from actual ROS packages, or if you don't have a package, you can provide it with an absolute path to a launch file.
In your case using the latter option would probably be possible. Something like this should work (provided there are no problems with the launch file itself):
roslaunch /path/to/your/catkin_ws/src/tag_detector_ros/launch/allTags.launch
Originally posted by gvdhoorn with karma: 86574 on 2019-03-07
