Hi, I'm having some problems with catkin build for my workspace. I've followed the next steps:
  1. $ mkdir -p ~/catkin_tools_ws/src 1. $ source /opt/ros/melodic/setup.bash
  2. $ cd ~/catkin_tools_ws 1. $ catkin init
  3. $ catkin build 1. $ source ~/catkin_tools_ws/devel/setup.bash
It builds correctly without errors or warnings, but if I type 'roscd' it sends me to /opt/ros/melodic and not to my workspace.
The weird thing is that if i create the workspace with catkin_make, it works perfectly.
Thanks for your time
Originally posted by Billion on ROS Answers with karma: 1 on 2019-03-03
Comment by gvdhoorn on 2019-03-03:
Are those really all the steps you do?
Because if you haven't source /opt/ros/melodic/setup.bash before step 2, catkin init should complain about "not extend[ing] any other result space", which woud lead to what you describe.
Comment by Billion on 2019-03-03:
Hi gvdhoorn, yes I did it but i forgot to add it in the description. However when i source the setup.bash of my workspace, ROS_PACKAGE_PATH continues to be only '/opt/ros/melodic/share'...
re: ROS_PACKAGE_PATH: I would say that is normal, as you have no packages in your workspace as far as I can tell.
If you want more specific help, edit your original question to show us the exact steps you take when initialising and building your workspace.
Thanks to you for your time :)
Thanks for the update, but just making sure: I don't see a cd ~/catkin_tools_ws anywhere. Without that catkin init runs in the CWD, which I doubt is what you did/wanted.
Originally posted by gvdhoorn with karma: 86574 on 2019-03-03
