Hi
I am trying to get navigation to run on my robot. To do this I am currently trying to get AMCL to work on ROS kinetic (ubuntu 16.04 Xenial).
My setup consists of 3 machines (of which 2 are relevant). I have:
  • My server: which is running a roscore, amcl, robot control software etc
  • A raspberry Pi 3 with a RPLidar A3 connected running the lidar ros pacakge ''
  • A virtual machine running Ubuntu 16.04 on my computer which is used to run GUI's Rviz, rqt_tf_tree, ...
Data can be published and received from all machines so I think this is working (I set the ROS_MASTER_URI, ROS_HOSTNAME and ROS_IP variables and I edited the /etc/hosts file)
The lidar works and publishes data correctly (confirmed in Rviz and through rostopic echo). image description
However AMCL gives the following error every 15 seconds:
[ WARN] [1551364654.979541753]: No laser scan received (and thus no pose updates have been published) for 1551364654.979506 seconds.  Verify that data is being published on the /rplidar topic.
I do not get the error when using a different laserscan (the one from the robot instead of the RPLidar for instance). I have tried letting the lidar publish to the base_footprint frame directly as well as to a separate 'laser' fixed frame for which I then run:
rosrun tf static_transform_publisher 0 0 0 0 0 0 1.0 base_footprint laser  50
Running roswtf on the server machine does not yield anything useful (only some unconnected topics). Running it on the Raspberry does however:
WARNING Received out-of-date/future transforms:
 * receiving transform from [/naoqi_driver_node] that differed from ROS time by 86.070399184s
 * receiving transform from [/static_transform_publisher_1551361858545724424] that differed from ROS time by 86.129054226s
The same info is given when i run roswtf from the virtual box machine.
A screenshot of rqt_tf_tree is below: image description image description
And output of rosrun tf tf_echo base_footprint laser:
At time 1551365866.147
- Translation: [0.000, 0.000, 0.000]
- Rotation: in Quaternion [0.000, 0.000, 0.000, 1.000]
            in RPY (radian) [0.000, -0.000, 0.000]
            in RPY (degree) [0.000, -0.000, 0.000]
At time 1551365866.898
At time 1551365867.899
I am totally at a loss so any help would be greatly appreciated
Regards Christof
Originally posted by cmahieu on ROS Answers with karma: 3 on 2019-02-28
Receiving transform from [..] that differed from ROS time by 86.129054226s
With "multiple machines" and issues with TF / subscribers the first thing to check would be time synchronisation across all machines involved. Can you confirm you've done that?
Edit:
I had no idea synchronization was something to take into account.
It is pretty logical though, if you think about it: how would we be able to temporally correlate sensor data (or more generally: publications) coming from different machines without a common/shared/synchronised clock?
I quickly forced synchronisation by taking the desyncrhonized data and publishing it to a new topic without the old time info and this works (as a temp solution).
You probably already figured it out, but republishing like that is certainly not a real solution.
Take a look at wiki/ROS/NetworkSetup - Timing issues, TF complaining about extrapolation into the future? for a solution.
Originally posted by gvdhoorn with karma: 86574 on 2019-02-28
Comment by cmahieu on 2019-02-28:
Hi
I had no idea synchronization was something to take into account. I quickly forced synchronisation by taking the desyncrhonized data and publishing it to a new topic without the old time info and this works (as a temp solution). Thank you! I would not have been able to solve this without you!
