I am following this answer to export a .pgm and a .yaml from a database file generated using RTAB-map.
But when I run
rosrun rtabmap_ros rtabmap _database_path:=IROS14-kinect-challenge.db
I get a message saying that /rtabmap did not receive any data since 5 seconds. I know there is no data being published into /odom, /rgb/image, /depth/image,/rgb/camera_info
but shouldn't this data be coming from the database file?
When I run
rosrun map_server map_saver map:=proj_map
I get this message:
[ INFO] [1551154609.903198676]: Waiting for the map
and
rosservice call /publish_map 1 1 0
doesn't do anything.
  • I am running ROS melodic on Linux Mint(Ubuntu 18.04).
  • I have downloaded the IROS14-kinect-challenge.db file from here
  • I have double checked that roscore is running. :D
Originally posted by Drkstr on ROS Answers with karma: 25 on 2019-02-25
I am on ROS Kinetic, but rtabmap is the same version than on Melodic and I cannot reproduce the problem. Following exactly what you did, after doing rosservice call /publish_map 1 1 0, I see in the rtabmap_ros terminal:
[ INFO] [1551304861.803715934]: rtabmap: Publishing map...
[ WARN] [1551304862.123340986]: Many occupancy grids should be loaded (~698), this may take a while to update the map(s)...
[ WARN] [1551304872.284061124]: Map(s) updated! (10.160718 s)
[ WARN] [1551304872.284428237]: /proj_map topic is deprecated! Subscribe to /grid_map topic instead.
so the map is created, then on map_server terminal, I can see:
$ rosrun map_server map_saver map:=proj_map
[ INFO] [1551304856.764290592]: Waiting for the map
[ INFO] [1551304872.285442346]: Received a 551 X 447 map @ 0.050 m/pix
[ INFO] [1551304872.285460183]: Writing map occupancy data to map.pgm
[ INFO] [1551304872.289321822]: Writing map occupancy data to map.yaml
[ INFO] [1551304872.289390615]: Done
The map created: image description
The warnings that it did not receive any data since 5 seconds are normal, as no sensors are publishing topics to rtabmap.
Originally posted by matlabbe with karma: 6409 on 2019-02-27
Comment by Drkstr on 2019-02-27:
Ah, looks like I just needed to wait a bit :D Thanks for your response.
