Hi,
I am using ur10 ros driver to get the position of a mounted drilling pin on the end-effector of the robot. I want to do a transformation between the end-effector (tool0_controller) and the drilling pin frames. I measured the distance and orientation between them and tried to do a static transformation as the following but can't see any changes when I echo the /tf topic
  <node pkg="tf" type="static_transform_publisher" name="tool0_controller" args="
   0.5 0 2
   0.707  0.707 0 0
    /base_link/base /base_link/base/tool0_controller 500"/>
Any clue?
Edit: Simply the question is that I am trying to control a drilling pin that is mounted on the end-effctor of the ur10 robot (tool0_controller frame). I tried the static transformation above but it wasn't working
I tried to add a new frame to tool0_controller and this is the code I am using but the problem here is that: the pose published by drillingPin frame is relative to the tool0_controller not to the base.
  #include <ros/ros.h>
  #include <tf/transform_broadcaster.h>
  #include <geometry_msgs/PoseStamped.h>
  int main(int argc, char** argv){
  ros::init(argc, argv, "my_tf_broadcaster");
  ros::NodeHandle node;
  tf::TransformBroadcaster br;
  tf::Transform transform;
  ros::Rate rate(10.0);
  while (node.ok()){
    transform.setOrigin( tf::Vector3(0.0, 2.0, 0.0) );
    transform.setRotation( tf::Quaternion(0, 0, 0,1) );
    br.sendTransform(tf::StampedTransform(transform, ros::Time::now(), "tool0_controller", "drillingPin"));
    rate.sleep();
  return 0;
I am pretty sure this is a common application to universal robots but can't find useful tutorials. Your help is highly appreciated!
Originally posted by raghad.husari on ROS Answers with karma: 3 on 2019-02-25
Comment by gvdhoorn on 2019-02-25:
Can you clarify what you want to do exactly? You cannot "override" a TF frame being published by ur_modern_driver, so that wouldn't work.
I'm also confused by this:
which frames are these supposed to be?
Finally: 500 is the period, not ..
.. the frequency/update rate, so this is only publishing at 2 Hz. Probably not what you intended.
Comment by raghad.husari on 2019-02-25:
I mounted a drilling pin on the end-effector and want to get the position of that drilling pin from the ur driver. The position of the drilling pin is located at specific distance relative to the tool0-controller frame, let's say at x=0.5, y=0 and z=2 with no orientation.
the parent frame is /base_link/base and the child frame is /base_link/base/tool0_controller, I am trying to apply a static transformation to shift the child frame to the drilling pin position
tool0_controller is a frame that is published by ur_modern_driver, you cannot "shift it". Your publisher will conflict with the driver.
I'm still confused, but I would recommend you introduce a new frame that encodes the location of your drilling pin relative to tool0_controller.
Comment by raghad.husari on 2019-02-27:
Please see my reply below @gvdhoorn
This shouldn't be so difficult and wouldn't even require writing a custom TF broadcaster.
If you have a custom frame that is relative to tool0_controller, you have two options:
  1. if it's a static frame (ie: does not include any dynamic rotation or translation): use static_transform_publisher. Something like this would add the frame you show in your edit:
    rosrun tf2_ros static_transform_publisher 0 2.0 0 0 0 0 1 tool0_controller drillingPin
    Two things to note:
    1. don't use uppercase characters in TF frame names (or any graph resource): see wiki/Names.
    2. ROS uses metres for distances, so the 2.0 you have there results in a Y-translation of 2 metres relative to tool0_controller. Most likely not what you intended.
  2. add drillingPin as a link to your composite xacro/urdf (the one that combines the UR xacro with your end-effector) and use a fixed type joint to link the two together. The robot_state_publisher will then do all the hard work for you.
Which of the two options you choose doesn't really matter I believe. The static_transform_publisher would need to run all the time, so would result in an additional node, but seeing as it's a static TF frame, won't result in too much overhead.
re: not relative to base: well, no. You specify it as a transform relative to tool0_controller, so it's exactly as you specified.
That doesn't mean you can't query TF for the transform between base and drillingPin though.
Originally posted by gvdhoorn with karma: 86574 on 2019-02-27
