Let's suppose I have nodes A, B and C on a MultiThreadExecutor with two threads.
Then suppose that the Event Queue has the following events: Node A Callback1 | Node A Callback1 | Node B Callback 2
From what I understand:
  1. The first thread takes the Node A Callback1.
  2. Then the second thread takes the next Node A Callback1.
This will mean that callbacks on the same Node should be thread safe when using MultiThreadExecutor, is that true? Is there a way to guarantee that the callbacks of the same node are executed sequentially or that each node has its own thread?
Thank you
Originally posted by Teckel on ROS Answers with karma: 103 on 2019-02-23
Your understanding is correct.
This is what callback groups are for. Adding a node to a MutuallyExclusiveCallbackGroup (rclpy) (MutuallyExclusive callback type (rclcpp)), will ensure that its callbacks are executed sequentially.
Originally posted by jacobperron with karma: 1870 on 2019-03-04
Post score: 5
Comment by Teckel on 2019-03-04:
Thank you. You have pointed me in the right direction. Now I am sure that I should correct some mistakes on my project.
