Is there a way to launch the database file and publish it to ROS when running in simulation, i.e. when the sensors are not connected? I would just use it for visualization and for generating the collision scene, not for localization. By simulation, I don't mean in a physics engine like Gazebo.
I just want the cloud_map topic to exist including the service to visualize the map in RViz. I don't want any data from the time of creating the map to be replayed, especially the tf frames. Ideally, rtabmap_ros rtabmap.launch is not launched.
Originally posted by achille on ROS Answers with karma: 464 on 2019-02-22
Note sure I understand well the question, but there is what you can do with a database:
  1. Play database like a rosbag (though it is recommended to use directly a rosbag if it is what you want to do):
$ rosrun rtabmap_ros data_player _database:=~/my_map.db --clock
  1. Start rtabmap with the database as input, then subscribe to /rtabmap/cloud_map and call service /rtabmap/publish_map to get the map:
    $ roslaunch rtabmap_ros rtabmap.launch database_path:=~/my_map.db $ rostopic echo /rtabmap/cloud_map $ rosservice call /rtabmap/publish_map 1 1 0
EDIT
  1. Without rtabmap.launch:
    $ roscore $ export ROS_NAMESPACE=rtabmap && rosrun rtabmap_ros rtabmap _database_path:=~/my_map.db $ rostopic echo /rtabmap/cloud_map $ rosservice call /rtabmap/publish_map 1 1 0
  2. For RVIZ with rtabmap_ros/MapCloud display, launch rtabmap node in rtabmap namespace, then in RVIZ's MapCloud plugin should be able to click on Download Map:
    $ roscore $ export ROS_NAMESPACE=rtabmap && rosrun rtabmap_ros rtabmap _database_path:=~/my_map.db $ rviz
  3. For rtabmapviz, we can do something similar:
    $ roscore $ export ROS_NAMESPACE=rtabmap && rosrun rtabmap_ros rtabmap _database_path:=~/my_map.db $ export ROS_NAMESPACE=rtabmap && rosrun rtabmap_ros rtabmapviz
Originally posted by matlabbe with karma: 6409 on 2019-02-25
Comment by achille on 2019-02-28:
This works but given more thought it's not what I'm looking for. I updated my question with more details
Comment by matlabbe on 2019-03-03:
updated the answer with more examples
Comment by achille on 2019-03-12:
The edited answer works for me with Rviz when the namespace is set to export ROS_NAMESPACE=rtabmap/rtabmap instead of just rtabmap. However I get the Did not receive data since 5 seconds! on the rtabmap node. Can mapping not just be disabled? I do have the ability to suppress warnings but I'm hoping there's an actual fix.
Comment by matlabbe on 2019-03-15:
you can set _publish_tf:=false to disable map->odom to be published.
Comment by achille on 2019-03-19:
That doesn't get rid of the warnings. The rtabmap localization node is still running and looking for messages on the camera topics.
Comment by matlabbe on 2019-03-22:
If there are warnings telling that camera topics are not received since 5 seconds, and you don't plan to feed topics to the node, you can ignore the warnings (rtabmap is waiting for topics and do nothing actually).
Comment by achille on 2019-03-25:
Solved the warnings by setting the output argument to 'log' when running in simulation. Thanks!
