Hello,
I have a Motoman MH50 robot with DX100 robot controller. I want to use it for pick and place application using Moveit!. In tutorial it is suggested that to order some part number to work with DX100 CONTROLLER:
What is use of this part number?
The MotoROS application and source is available for public download. However, ordering this part number will ensure your controller is updated with correct system software, the MotoROS driver is installed, and all internal parameters are properly configured.
Or is it optional according to above line?
Is it sufficient if I only load MotoROS binary in controller?
Thanks.
Originally posted by nd on ROS Answers with karma: 80 on 2019-02-20
In tutorial it is suggested that to order some part number to work with DX100 CONTROLLER: [..] What is use of this part number?
It's not actually suggested, it's a requirement.
From motoman_driver: Requirements:
However, for DX100 controllers, a specific software option must be explicitly ordered from Motoman in order to enable ROS-Industrial integration (see the MotoPlus Runtime License section below).
The MotoPlus Runtime License section then shows this:
image description
The license enables the controller to run a MotoPlus application, with MotoPlus being the SDK in which MotoROS is written.
No -- as I hope is clear now -- as that would not allow you to actually run it.
For that you'd need the license as well.
Originally posted by gvdhoorn with karma: 86574 on 2019-02-20
Comment by nd on 2019-02-20:
Thanks for the clarification. it is not free right?
Comment by gvdhoorn on 2019-02-20:
Afaik: no, it's not free.
thanks....
